codes
Old Jan 2, 2019 | 04:41 PM
mac27041's Avatar
mac27041
codes
ford 350 7.3 2002
the engine light is on two codes
P0118 PO470
tried to clear the codes no luck light goes off then light back on
after replaceing the temperture unit the other the back pressure not sure were to look for that one , also checked the heat relay switchs for gp check good and plugs check ok but hard to start when cold , does not idle up when cold no smoke also checked the wiring for the gplugs all ok
hot are cold vin 1ftww32f22eco2260
emer brake does not hold ,new shoes and kit installed cable is good and is working the shoes the adjustment is good
Is any one here I don;t think anyone is back there :{
all so the
cruise and door locks do not work fuses are good
Had this truck for a few weeks
PagosaFord
Jan 23, 2018 11:56 AM
MisterDave2
Jan 17, 2009 10:47 AM
sweetsride
Feb 1, 2008 10:46 AM
rustydailey
Sep 16, 2007 10:40 PM
dsh82
Nov 22, 2002 01:49 AM
