4x4 not working
Initial thoughts are to jack up front end with both wheels off the ground and see what happens when each wheel is manually turned. I was going to do this in 4H, 4L, and 2H. And also with the tranny in and out of gear.
Is this the right path? If not, what am I missing? Also, what results should I look for if everything is normal (because I know it isn't)?
Advanced Search yielded no results due to 'common terms'..
Thank you.
Even before you lift the front end up though, in the comfort of your driveway put it in either 4wd position and try to turn the front shaft by hand. If you can still turn it, the fault is in your transfer case shifting.
If the front driveshaft locks up, it's in 4wd and the problem is in front of that.
Aftermarket lockouts often fail, so it can easily be those. And we'll hope for that, because I think the only other possibility is the differential, as busted gears or axle shaft(s).
Paul
"Comfort of my driveway" is relative though, as we've got about 3' of snow on the ground.
I was going to write "...of your garage." at first, but thought that maybe not many of these rigs get the luxury of a garage.
Although I sure have seen a lot of nice shops/out-buildings/barns that some of the members here have for their trucks! Jealous for sure.
Paul
No, I did not hear any attention-getting noises. The truck makes loud noises all the time, and I could have easily missed it simply driving around. I put the new Warn hubs in 2 summers ago and the noises calmed down considerably.
If you have a functioning "limited-slip" differential (optional on some trucks) losing one hub would not stop the other wheel from turning most of the time. With enough traction on the one good side, the clutches in the limited-slip would start to slip and both would then do nothing because most of the torque would be transferring to the spinning axle with the busted locking mechanism. But in the snow, neither tire is likely to get too much traction.
There are true lockers (with gears, teeth, and other implements of destruction) that will still get power to at least one of the wheels even if the other is not functioning properly. But even though the word "lock" or "loc" or "lok" or some variation was often in the name, I don't remember any factory ever offering an actual locker in a factory axle. Other than maybe the "Gov-Lok" in GM axles that did have a little bit of lockage after enough slippage. But that's another story.
Nowadays though there are actual lockers in some vehicles.
So a "four-wheel drive" truck with open diffs is actually only a two-wheel drive truck in reality. To be truly four-wheel drive, you need some sort of limited-slip or locking differential in both ends.
Too much information? Hah! It's fun though, all this typing.
The short version? Yes, you could have just one Warn hub not working and you would have had the results in the snow that you experienced.
Paul
My hypothesis is that the intact ones backed out one at a time till finally the rest couldn't handle the torque and sheered off. I'm also assuming the remnants of each sheered off bolt is still in the bolt hole and will have to be drilled out.
I have a set of new bolts but I'd like to ask you guys to look at some pics of my damaged ring gear and see if it's absolutely necessary to replace said ring gear? I can't tell if the pinion is damaged or not.
This truck is used sparingly around my property and to run to town (20 miles) once in awhile.
I looked at R&Ps on JBG and would really like to spend less money on this truck.
Suggestions are appreciated. New R and/or P? New carrier? Just the bolts?
Thanks as always.
Both carrier and ring are damaged
No idea what happened to bolt #10
I can't remember ever hearing it happening to a factory assembled piece, but many rebuilds (especially in the rear) lose their bolts for some reason. The "assumption" is a careless installer. But it seems more common than that would indicate.
But I suppose if a truck is used hard enough, just about anything can happen.
To your question of what to do, I'd say more parts are needed than just the gears. While you might get away with it, and depending on how you use it in 4wd, might get away for a long time, I think there is too much potentially unseen damage to just go with the minimum.
The differential carrier assembly is obviously damages heavily on it's ring gear flange. This could just be cosmetic, but it could easily have compromised the housing and started cracks. When that thing rolled over a bolt or three, that was a crap-ton of force!
Way too many crack in a circle around the ring gear bolts, but in an open diff I don't thing they have the same stresses during normal use. But in this case, it's had plenty of stress from other sources.
Nope, I'd do a "while I'm here" thing again and replace all the usual suspects. New parts all around. Including a new carrier.
A new open carrier is pretty cheap, and a limited slip probably starts at just under $300 or so and goes up to $800 lockers (that you end up spending $1500 on!). Or whatever an ARB costs these days.
But even for me, and even in a "while I'm here" scenario, if I don't need a limited-slip or locker, I'm not paying extra for one either. So at the very least, a new or used open carrier, new ring-n-pinion gears, new bearings and get 'er done.
In this case, if it's just a work truck, or around the ranch truck where you might use 4wd a lot, but not under a lot of stress, used parts would be perfectly fine.
Lots of people upgrade or change the gearing in their rigs and would love to get a few bucks for their old stuff before they throw it all away. Maybe someone has some in the classifieds right here on the forum?
Good luck.
Paul
How is $250 for a front axle assembly? It’s a closed knuckle from a ‘74 but the ratio is the same.
A closed knuckle is not going to be able to use disc brakes, unless someone has come up with a work-around in the last few years?
And the maintenance of a closed knuckle when they start to leak out the ends (which they always do) is more involved than an open-knuckle too.
Might not be a bolt-n-go if you have to rebuild the outer ***** and seals. Assuming the pivot-ball surface is in good shape still.
Be very sure you need one then, before you go closed. It's a good price for a part someone is looking for to do a restoration of an older rig, as long as it's in great shape.
But otherwise it's a downgrade for you.
Paul
Mark.
