I think I want to go that way..Right now I have a good street engine but I want more torque, I dont want to replace my engine with a 429 or a 460. Ive alrady got alot of money in my 351m right now...
So really how much more power can I get out of this setup when I convert my 351m to a 408, I think thats what it would be..my engine now is punched .030 over, .510/ .536 lift cam, my heads have been shaved .030", 3-angle v-job, new stainless valves, new brass guids, high performance double valve springs, Roller rockers, and the ports cleaned up..The intake is a performer 400, with a 750 carb, I know the carb is too big but it was gave to me.. I got a edelbrock calibration kit I used to jet it down some, runs better now dont flood half as bad, but its still hard on plugs.. Long tube hedman headers.. Accel coil and pulg wires..I think that all I have done to the engine right now
I would like for someone to help me out some on my question, cause I dont want to do this and it not help out much on my power.?confused?
Without knowing how much power your engine puts out now, it's pretty hard to say how much more it would put out if you changed something.
If you could give more detailed cam specs (such as valve timing events at specified lift), maybe one of the guys on here with Desktop Dyno software can run some theoretical numbers for you.
IMO, if you've got a recently built engine, and you're not dissatisfied with the performance you have now, your money is better spent on tuning the engine you have to optimize it.
Originally posted by 84mustang Using Desktop Dyno, I estimated 8.5:1 compression for the 351.
It came up with 381 Ft/lbs of torque @ 3500 RPM
and 325 HP @ 5000 RPM
using 9.5:1 with the 400 crank, everything else the same it says
443 ft/lbs @ 3000 RPM and 338HP @ 4500 RPM
That was done using head flow data that someone else had posted, and long tube headers with Mufflers.
Hope that helps,
Jerry
Its bound to have more than 325 horse I think... because it ran a 13.64 @97 mph about two weeks ago at the track, and that was on street rubber. I would love to get it down into the 12's, I was just thinking of Ideas to try and get it in the 12's if that was possible with a 351m..lol
I was reminded tonight why I love the 400 for torque. I went and bought a 25' travel trailer. On the way home the fuel pump started to go south. Anything more than 1/4 throttle or 2000 rpm it would start to nose over. ( Yeah I checked the filter, no such luck this time.) It pulled the trailer 20 miles uphill to my house with me never having to get out of 4th gear most of the way. Just chugging along at 1500 and pulling like mad.
