Fuel system
Old Dec 31, 2018 | 07:51 PM
PrincessJo's Avatar
PrincessJo
Fuel system
My problem is..when I put gas in my back tank it pumps it all to the front tank then act like it's out of gas.
Old Dec 31, 2018 | 08:57 PM
timbersteel's Avatar
timbersteel
Common problem on dual tank trucks. Cross fuel transfer problem due to bad check valve in front tank.
You can remove the front tank and assembly and plug the lines.
I've included a link.
https://www.ford-trucks.com/forums/7...uel-lines.html
Old Jan 1, 2019 | 10:48 AM
josiewales's Avatar
josiewales
The fix depends on the year model truck you have. On my '88 I had to replace the "dual fuel reservoir". Not terribly expensive or hard to do. But later years had a similar problem different fix.
Old Jan 1, 2019 | 11:30 AM
timbersteel
Josiewales is correct. I was thinking of the engines that have the entire FDM in the tank.
SouthernBlues
Feb 2, 2017 05:39 PM
steelear
Apr 3, 2014 10:33 PM
MFW
Mar 8, 2014 07:53 PM
Mike92f350
Nov 4, 2003 06:54 PM
k3ke
Feb 2, 2002 06:57 PM
