Brake caliper issues
I think I've done this before here but I'll throw up some of the pictures I still have from a pictorial I did for the aftermarket guys in the company on servicing details. I don't have them all.
When the boots get damaged which is usually from the heat, they let moisture into the bracket pin bore and corrosion starts to develop.
You usually can see some oxidation forming in the bores, it's usually much worse than this.
The original surfaces are a honed finish, not unlike an engine cylinder bore, but there is wear from caliper movement.
The best mechanical way to clean them after washing out the silicone is with a ball hone, which will be different sizes for the front and rear calipers. But you want to preserve the diameter of the bore as much as possible, and when doing this the factory anti-corrosion finish is removed. This process is often done with purchased rebuilt calipers. A wire brush will be less abrasive, which can be a tube brush or a gun barrel brush.
Sometimes we will see burned caliper piston boots, which is likely if the brake pads were replaced with high metallic aftermarket pads or the heat shields were not reinstalled from the early model design.
Those Gen 1 shields were eliminated during Gen 2 developments, and the mounted noise insulator extended up the top of the pads to protect the boots from high temperatures. However, many of the aftermarket pads do not do this, and it's even evident on the Motorcraft replacement pads, which is ironic.
While looking at those pads, many people get into trouble by not retracting the caliper pistons far enough in so the noise insulator retaining nubs clear the pistons during removal. It's very evident when there is this type of damage to the pistons and the person removing the calipers blames the phenolic pistons from cracking. That's not the pistons fault.
Trucks that snow plow, see extensive chloride de-icer exposure, or even sitting for long periods of time suffer from rusting within the caliper bracket. This can reduce pad freedom in retraction from the rotors or just lock the pads to the rotors. This will result in uneven wear of the rotor rubbing surfaces (pulsation) or overheating of the brake which will then be the cause of burned slide boots or piston boots.
These surfaces are critical on the pads for freedom of movement. In the aftermarket industry, the tolerance in stamping is not controlled as well as the OE manufacturer does (used to be me). With new pads, this freedom needs to be checked during installation and sometimes corrected. Sometimes it's just excessive paint, sometimes the steelback tab is too wide or high.
The OE stamping spec was +0.000"/-0.010". The aftermarket stampings, used to be from Aimco or NRS were =0.010"/-0.010". That little 0.010" takes up a lot of space in there. Today there are many stampings out of China.
But in-service as mentioned about can just develop too much rust, on the steelback tabs or under the stainless steel slippers from the bracket. Again this prevents freedom of movement of the pads. The caliper body and pistons may have moved away from the rotor on brake release, but the pads do not. And the clearance here is designed tight to prevent noise.
Cleanup can be as easy as just a wire brush, or at the pad's ends may need to be done abrasively.
Using a small amount of silicone based grease on these surfaces is the best choice to prevent any rusting, but only a small amount as to not contaminate the friction material surfaces as it can migrate in use.
Anyway, my quick tips for the day.
I took them apart and there was hardly any grease at all on the slide pins, so I lubed them with the green “Ultimate Disc Brake Lube” before installation.
Both calipers I took off moved freely on the slide pins, but on the passenger side both pistons were tough to compress.
Because I go no more than 6000 between taking them apart, no rusting or pitting here, just dry pins. I usually catch them at the right time avoiding a real mess. The OE pads from Ford are still reasonable from the dealer, around $40-45 a set. I never let the pin boots get ripped or torn and always replace one that may appear to be worn, they are cheap insurance.
So how does one retract the pistons to avoid damaging them when taking the calipers off? I've always just removed the bracket and caliper at the same time.
But I normally remove both with the bracket as well.
Man, if I took them apart every 6k miles that would be every 6 weeks...don’t think I’m willing to do that. And so far every caliper I’ve replaced over the last 4 years the issue hasn’t been the pins, it’s been the pistons. Guess I’ve been, ummm, “lucky”
There were a number of us that thought the change from the Generation 1 front slide design to the Gen 2 was a bad mistake, and even worse with the Gen 3 added rubber bushing. Gen 1 was as the rear pins are, an internal boot fitting groove which tightened with any rusting, while the Gen 2 boot seal was exterior. The 2003 still has a Gen 2 with the removal of the bushing, but I have a set of the brackets from the Gen 1 series as someday backups.
Passenger side piston resistance to moving is either from the seals getting hardened from aging, or some rust getting under the boots or o-rings and grabbing the pistons. And sometimes it's just adhesion of the rubber o-ring to the piston and pushing the piston in breaks that up, its like being a caliper piston chiropractor.
During new caliper design testing measuring seal rollback and piston movement (knock back) force is tested. There typically are values for new components and then after the caliper has been oven baked for a set period of time and temperature mimicking in-service. Testing is done on a machine such as this from Link.
Typically you start out with a total clearance pad to rotor of about 0.015", half that each side. Brakes used to have wider spacing but that results in a longer pedal travel. The problem with the long wear mileage we get out of friction material today with some SD's getting over 100k before a pad change, the seals loos resiliency so they don't cool as well, rotor off-braking wear is higher from pad contact, and of course fuel mileage is lower. So sometimes even when you're at 100k and changing pads, you also need to think about seal aging.
But it sounds like you caught that caliper before it became a real issue.
The need to push the pistons in is dependent on the height of the pad's nubs (vary by manufacturer) and how well the caliper pistons rollback on brake release. I've not had an issue myself, but there's a lot of those type of caliper damaged pistons out there. But it's a safer to get some clearance, especially if the calipers resist coming off.
We had, and I have large C-clamps.
But you can go Neanderthal if your careful, prying the caliper while catching the edge of the rotor with a flat blade screwdriver.
Once the caliper is off you can use the C-clamp to further push the pins in or use a tool like I have from Blue-Point.
Over the years I used two different greases for the pads and the slide pins, the standard silicone caliper grease and Dow's 77. The 77 is a high temp silicone grease with Moly, it's the same grease used by Honda (another manufacturer we sold pads to) on the back of the pads for noise abatement. But it's really high in viscosity and when used for the pin slides created too high of a hysteresis. Iv emoted to nickel based anti seize on the pins for this last changeout, just a thin coating, and it seems to do well. Sometime this spring I'll probably find out how it does with parking lot rot of almost 2 years.
), wanted to thank you for the wealth of information you have been kind enough to post. I’m still processing it all but hope to soon have these nuggets all in my head.I’m just glad I check at least every 5k miles when I rotate tires and caught this...the pads had only about 1.5mm left before the backing plate! The driver side pads were only about 1/3 worn.
Is it weird that whenever I’ve had issues with the rears it’s always been a slightly dragging issue, but whenever I’ve had issues with the fronts it’s a “fast and furious suddenly it’s pulling to one side and smoking” kind of thing?
Now I almost feel like I should be driving around with a full set of spare calipers...just in case! 😳
Its all a lot of eccentric data that only makes sense if your in the industry and detail the crap out of all this. Some mechanics have all this figured out, and some go Huh?
A rear brake doesn't yank the steering wheel like the front brake can. Heat with semi-metallic pads alters the friction coefficient, and these trucks have a high scrub radius (another detail) which make inconsistency left to right a bigger pull issue. It's why there was a TSB to replace pads with the same lot numbers if a customer complained about brake pulls.
Ah, the fun times ...... just do anything to get the warranty down.
What I meant by the difference between the issues rearing their heads front and rear is the rears seem to be a slow process of starting to drag and may not even notice for a while, whereas the fronts seem to come on strongly when they have an issue. I drove back from Ohio to WV and got the best fuel economy I’d ever gotten...two days later my right front caliper was dragging so bad it was pulling and smoking. Rears have never gotten so hot that they’ve smoked when they’ve had an issue. I’ve always noticed the uneven rear pad wear when rotating the tires every 5k at oil changes. Fronts have always been even when I check them, and then suddenly there’s a big problem.
It seems that I replace fronts 2-1 as well, say's how much more the fronts are used for stopping.... ever notice the fronts are caked with dust and the rears hardly have any on the wheels?
Whenever I’ve replaced fronts the pad thickness has been the same between the majorly dragging side and the good side. It just happens suddenly. When I’ve replaced rears there’s always been a big discrepancy in the amount of pad wear between the good and bad sides, which I assume means it’s been dragging lightly for a while.
