Odometer failure
Old Dec 28, 2018 | 11:09 PM
DriverD's Avatar
DriverD
Odometer failure
97 E150, the speedometer works fine. However, I notice that the odometer does not reflect the miles driven. I have noticed that it quits advancing at times, both the main and trip odometer. I usually see this at the same .75 miles on the trip meter. Maybe a gear tooth is missing?
Does anyone rebuild these instruments, or should I just put up with it?
Old Dec 29, 2018 | 04:21 AM
JWA's Avatar
JWA
Just the odometer and trip meter can be replaced and even reset depending if you're willing or able to almost completely disassemble the instrument cluster----I've done this myself on the clusters up until 2005. So you don't have to live with this if you'd rather not.
I might have an instrument cluster or two fitting your era would use, yours for the cost of shipping only. These could be used to retrieve the odo and trip meter mechanicals. You could also visit a local scrap yard and look for clusters from F- or E-Series vehicles, all very similar and using common parts.
Here's an image showing the sub-assembly that is the odometer and trip meter:
There is also a seller on eBay who offers cluster repair/rebuild but I can't speak to the quality of his work. His feedback is great if that's any help.
Lemme know!
LSO1123
Jul 22, 2011 04:14 PM
DaviMac424
Feb 16, 2010 05:38 PM
Thunder Road
1997 - 2003 F150
May 29, 2009 08:29 AM
johnpvb
Jan 15, 2009 07:17 AM
