66 Hood Hinges
Old Dec 28, 2018 | 10:17 PM
DontKnowJackS's Avatar
DontKnowJackS
66 Hood Hinges
Searched backwards and forwards on this forum. Where can I buy buy the best replacement hood hinges? I see them on MAC's for $91.49 each. Thanks.
Old Dec 28, 2018 | 11:42 PM
resonateur's Avatar
resonateur
All the repro’s have a bad reputation because they are made overseas somewhere. I have one original left if you need....it will be very inexpensive!
Old Dec 29, 2018 | 07:16 AM
benbuilder's Avatar
benbuilder
I have a set off a 66 i parted out. if interested, email me chircolandinc@gmail.com
Old Dec 29, 2018 | 07:31 AM
DontKnowJackS
Thanks Ben. email sent from sammyleach@gmail.com
Old Dec 29, 2018 | 07:33 AM
DontKnowJackS
I need drivers side. email is sammyleach@gmail.com
Old Dec 29, 2018 | 09:17 AM
DontKnowJackS
Email sent
Old Dec 29, 2018 | 11:07 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1961/66 F100/1100 Hood Hinges
1961/66 F100/1100 // 1961/66 B500/750 (School Bus) // 1967/69 F800/1000:
The following should be genuine Ford NOS parts.
C2TZ-16796-C .. Right Hood Hinge / Obsolete/Reproduced
OBSOLETE RELIABLE PARTS in Nashville GA has 1 = 229-686-5101.
RPN PARTS in Erie PA has 2 = 888-864-9305.
GREEN SALES CO. in Cincinnati OH has 10 = 800-543-4959.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 132 = 800-476-9653.
C2TZ-16797-C .. Left Hood Hinge / Obsolete/Reproduced
OBSOLETE RELIABLE PARTS has 1.
GREEN SALES CO. has 10.
CARPENTER NOS OBSOLETE PARTS has 130.
Old Dec 29, 2018 | 11:49 AM
DontKnowJackS
Thanks Bill
Old Dec 29, 2018 | 11:53 AM
DontKnowJackS
I need drivers side. What button do you push to reply to a post directly?
Old Dec 29, 2018 | 11:59 AM
TA455HO's Avatar
TA455HO
Lead Gopher
A few years back Carpenter and other vendors were allowed to start posting their reproduction/aftermarket parts on both Rearcounter and Partsvoice so if you want original NOS make sure they are. Some of the vendors will tell you right up front if you call and all they have is aftermarket.
For example, take part number C5TZ-9A758-AH
https://www.rearcounter.com/C5TZ-9A7...arts50488.html
Dennis Carpenter shows 1,008 on Rearcounter and 1,018 on Partsvoice right now. Those are not going to be NOS. I suspect the same with the hood hinges. Some vendors will be NOS, but buyer beware once again.
Chad
Old Dec 29, 2018 | 12:14 PM
DontKnowJackS
Chad
Thanks Chad. I have an original set coming from benbuilder.
Old Dec 29, 2018 | 12:39 PM
NumberDummy
Chad
The thing is, are the parts that Carpenter sells genuine Ford NOS or reproductions?
Carpenter made a deal with FoMoCo, can buy parts direct from them that FoMoCo plans to obsolete.
For example, the C9TZ-13341-C T/S switch used on misc. 1965/69's. It was available from Ford, then obsoleted several years ago.
Within a month Carpenter had over 4,000 and now has 3,497. So, are these genuine Ford or repro's?
The hood hinges were also available from Ford, then obsoleted. They were also VERY expensive, with one side having a MSRP of $900.00!!!
Old Dec 29, 2018 | 02:29 PM
Sortofa65's Avatar
Sortofa65
National Parts Depot claims to have a right hand NOS hinge-they want $835. for it.
Old Dec 29, 2018 | 02:35 PM
DontKnowJackS
Whew! Glad I need the left side... I have an original set coming from benbuilder.
Old Dec 29, 2018 | 06:09 PM
daveengelson's Avatar
daveengelson
Been ordering parts thru DC over past few months and although listed under NOS # they are reproduction and imported. Also ordered Motor Craft voltage regulator and the packaging indicated item is made in China and found the male pins on the regulator were slightly smaller than the female connector on the harness, I have to use electrical tape to secure harness to the regulator. Beginning to see item listed as'Made in USA or may be Imported'??
Purchase hood hinges thru MAC'S several months ago with no complaints, pleased with quality and fitment.
