Wipers stop working on High at random
Old Dec 27, 2018 | 02:40 PM
Mikulh's Avatar
Mikulh
On my '91 F150 the wipers work fine in intermittent mode and on low, but on high they sometimes work fine and sometimes just stop working.
When they stop they seem to just freeze up (i.e. they don't park... they just stop in the middle of the windshield). When this happens I can turn them off and back on low an they'll start working again.
Does anybody know if I should suspect the wiper switch, the motor, or the intermittent module? Are there any tests I can run to isolate which one is going bad?
Old Dec 27, 2018 | 03:07 PM
TexasGuy001's Avatar
TexasGuy001
I would probably suspect a problem at the motor or maybe wiring. This might help.
Old Dec 27, 2018 | 03:52 PM
byronbgs's Avatar
byronbgs
You can also take the cap off your Intermittent wiper switch and remove the screw. Take off the **** and clean the contacts carefully and reassemble.
Old Dec 27, 2018 | 05:40 PM
My4Fordtrucks's Avatar
My4Fordtrucks
My wipers would randomly stop in low or high speed. Turn off the switch then back on and would work for a while. In my case was the wiper motor.
truck157
1997 - 2003 F150
Jul 20, 2021 08:08 AM
Powerstroke-7.3
Dec 22, 2012 04:56 PM
BrassMonkey
Sep 24, 2010 10:32 AM
Fox
Nov 20, 2007 06:19 AM
Str0ud
Electrical Systems/Wiring
Jan 16, 2005 12:32 PM
