Sponsored by: Auxito
im lost!!!!!
Old Dec 25, 2018 | 09:44 AM
Jason Smith1975's Avatar
Jason Smith1975
im lost!!!!!
97F150 4.6 LIKETHIS WHEN bought temp isfine then all ofsudden goes to 240to250 then drops 160 couple mins same i started with thermo then water pump inside old justa disk left top hose builds somuch presure
Old Dec 25, 2018 | 11:26 AM
alloro's Avatar
alloro
Check the temperature of the coolant where the upper hose comes out of the engine with a laser thermometer. If the temperature there doesn't rise with the gauge then the coolant temperature sensor is no good.
Old Dec 25, 2018 | 09:39 PM
stephen.osborne1's Avatar
stephen.osborne1
May have an air pocket in the cooling system. Exhaust leaking from the cylinder from a bad head gasket could be your culprit. Coolant can be checked for carbon. Good luck.
Old Dec 25, 2018 | 11:45 PM
Lime1GT's Avatar
Lime1GT
hOLYjeZZmaniTsnoTaracEtowRiteAThrEad!!! Slow down, put some comma's, periods, capitals and form a coherent sentence.
Old Dec 26, 2018 | 09:08 AM
alloro's Avatar
alloro
That tends to happen when people post with phones or tablets.
Old Dec 26, 2018 | 11:14 AM
Lime1GT's Avatar
Lime1GT
Oh, OK. I'm not a text er.
Old Dec 26, 2018 | 04:56 PM
Bluegrass 7's Avatar
Bluegrass 7
Two conditions.
1 Overheating.
2 Just the temperature gauge causing notice.
If overheating then goes back to normal, there is air in the system.
If no overheating, it's a sensor issue.
Determine which it is and take actions to clear it.
Gary E
1983 - 2012 Ranger & B-Series
16
Apr 14, 2010 07:09 PM
AlexanderGM
Aerostar
13
Jan 9, 2007 11:28 PM
tm3912
Apr 22, 2006 12:30 PM
Coheeba
Aug 10, 2005 08:19 PM
gwheeler
Apr 26, 2001 11:21 AM
