Hello everyone,
Just purchased a 2018 Super duty, but I need some running boards. I was wondering if a set from a 2015 F150 would bolt up? I thought I read that the 2015 F150 cab is the same as the 2018 F 250 is this true? I am looking at a set of AMP Research electric take off boards that are complete. If they fit I could save a ton of money.
Thanks in advance
ldmedic
Reason: clarification
I had a 17 F-150 same cab. I bought the Amp steps new for it. Dealer ended up buying it back due to issues, so I contacted Amp research & they said they’ll work on my new 18 F250. They say the part # is only different because the wire harness is slightly longer on the 150 due to location of placing the brain & where the battery is. They were correct, I just wrapped the harness once around something or other to pick up slack...all other part #’s are the same from 150’s to 250’s. Everything works as it should!
