shimming the injectors 7.3
#46
With your guidance and inspiration, I think that when my injectors start causing me problems I will probably just shim them. Who knows, I might get 500,000 miles or more out of them which is a huge cost savings.
Great job and thanks for taking lots of pictures and explaining everything you were doing.
I have worked on gas cars most of my life. injectors and turbos intimidated me. Not no more !
#47
#48
I have found when starting in cold, 40s or below, to turn key on, watch light and when light goes out i wait about 3 second more and then crank and it fires right up.. could that mean my glow plugs are getting old? I have the shim kit as well but don't see the need to use it thus far. do get good cold starts the few time a year I do cold starts..
#49
I believe the glow plugs stay on for about a minute after the WTS light goes out. On California models with the Glow Plug Control Module the PCM will keep individual glow plugs on as necessary.
Rebuilt the injectors in my truck and shimmed them as well. Truck will start on 15 degree mornings as soon as the WTS light goes off.
#50
Very encouraging to read your path of progress. I, too, have been letting a package of shims and new o-rings sit on the shelf for about 2 years, and need to just bite the bullet and get this done. My injectors have about 302K miles on them now, so this will be their first time out of the engine (to do the o-rings). I'm still debating doing the cups at the same time, but I've just about convinced myself to leave the cups alone on this dig inside and just do a good inspection and if they need replacing, do them at a later time as a separate effort.
Having heard your success, I'm tempted to just do the shims in the truck and even let the o-rings sit a while longer. Don't know.... gotta think on that one over a bit more!
Glad your efforts have paid off for you!
#51
Been in the low 40's every morning this week and it's been starting right up.
The wife drove the truck and said it runs much better
#54
#55
I found this video today while getting my woken up on and zombie watching YouTube...
It isn't too bad with the BSing around, but shows what sand_fiend accomplished for the most part.
https://www.youtube.com/watch?v=MzZPH8E20gQ
the trapped oil in the armature area inside the spacer will not drain out the small factory holes in the spacer when the oil is that cold. this is why the instructions say to drill them out.
my motor was about 60+ degrees and 4 of my spacers were full to the top when i took the armatures off .
the newer factory injectors now come with the bigger valley groove in them to drain the oil and not the small hole.
he didn't show that the armature shim go's under the armature plate. not on the top just to be clear.
My truck has been starting in 40 to 45 degree mornings for the last week on the first try.
#56
My truck is a daily driver and has never hauled a load... so its babied, except when I go out in the National Forest.
Original injectors.... have only replaced the o-rings and shimmed the armature plates.
When we do get cold weather here in Georgia, I park the truck out in the cold, just so I'll know IF its going to have a cold start issue. Better to catch a problem at home than out in the mountains on a lonely backroad to nowhere.
You did a lot to truck at one time... I'd be scared I'd forget something and it wouldn't start.... and I'd not know what I didn't put back correctly. You did good !
Oh... and I'd never let the spouse drive my truck.... she'd probably never let me have it back !
#57
she really liked and has been looking at the 2017 Camry SC. her old Hyundai was on it's last leg.
when the 2018 came out, she fell in love with the new look. So two months ago i bought her a new car. I got my truck back..
#58
I noticed that as well.. a lot of the nitty gritty, removing the shim screw, installing the shim etc. was MISSING.. but let show taking the fricken valve cover off. I appreciate these guys doing the videos but man show what everyone is wanting to see.. that is what i loved about diesel Ron (RIP) videos.. he showed all the steps to do the repair. I have that kit but have not read all the info so was not aware of drilling the holes out..
Yes i watched that video before i got in to it. that is why i said i doubled and triple checked all the plugs. he missed plugging in #8. one thing i noticed is that he did not drill the spacers ? or at least didn't show it. he had them out.
#59
UPDATE
First real trip in the truck this weekend.
I actually had to go over the grapevine. truck ran better than it has in a long time and seemed to run smoother than i remember.
I didn't have to get in to the throttle to climb the hill.
it did 80 mph up the hill at about 8 bls of boost at about 1/3rd throttle and it never had to down shift in my 80 Hp tune.
I had my dirt bike and gear in the back.
I believe i also picked up about 2 MPG. it normally takes a little more than a half tank to round trip it.
it did it this time just under half.
I guess my truck was running worse than i though.
Over time, I must have gotten use to the way it was running before.
