Sponsored by: Innova
cd player plays with no cd
Old Sep 28, 2003 | 05:15 AM
tiliana's Avatar
tiliana
Unhappy cd player plays with no cd
My 94 Explorer is possessed. The cd player tries to play when there is no cd in it. On a 15 minute trip, it does this roughly 20-30 times. I've tried a cd cleaner, I've tried blowing it out with canned air. Is there a solution other than replacing it????
Old Sep 29, 2003 | 08:25 PM
PrPlayboy's Avatar
PrPlayboy
What happens if you have a cd in and set the radio to play the tuner? Will it keep switching to the cd?
Old Sep 29, 2003 | 10:54 PM
tiliana's Avatar
tiliana
Yes. It keeps trying to play the cd if it's in there, and even if it's not.
Old Sep 30, 2003 | 03:58 AM
Truck123's Avatar
Truck123
Is it built into the radio or a changer? My 97 did the same thing, and I have a changer in the center console. I pulled it out, cleaned it, put it back in and it works fine. There was a couple pennys, dimes, nickles inside of it. I have no idea how they got there (7 y/o son), but it works well now. Im not even sure if that was the problem, nor do I think it was, but either way, I used canned air, and it did the job.
Old Sep 30, 2003 | 06:39 AM
tiliana's Avatar
tiliana
It's built in.
Old Oct 5, 2003 | 12:33 AM
LLENFLORIDA's Avatar
LLENFLORIDA
HI!GEE I HAVE THAT SAME PROBLEM!I COULD HAVE THE RADIO ON,THEN THE DISPLAY SAY'S CD. AND GOES ON AND THE RADIO CUT'S OFF.IF I DON'T HAVE THE RADIO ON,THE CD START'S UP BY IT SELF.93EXPLORER.I WROTE BEFORE ABOUT THE ENGINE LIGHT BEING ON.IT WAS THE STARTER.I HAD MY ELECTRIC WINDOW FIXED,AND THAT'S WHEN I HAD THE PROBLEM WITH THE CD GOING ON.
Old Oct 5, 2003 | 03:07 PM
LLENFLORIDA
CD WORKS WITH NO CD
Old Oct 5, 2003 | 03:09 PM
LLENFLORIDA
SO DOES ANYONE KNOW HOW TO FIX THAT?IS IT A HARD JOB?
Old Oct 9, 2003 | 07:49 PM
Aftrmidnite's Avatar
Aftrmidnite
Aren't kids wonderful? I had a Radio with a cassette player, the Radio wouldn't come out of cassette mode, and it ejected any cassette. I bought a new unit, as soon as I got the radio out, 3 coins came tumbling out. Luckily I hadn't opened box and was able to take every thing back. PS I had seen the coins in there,but they looked like a couple of gears.
Old Oct 12, 2003 | 10:48 PM
LLENFLORIDA
SO !TELL ME WHY DOES IT GO ON.IS THERE A FUSE THAT I COULD POP OUT?
Old Oct 12, 2003 | 11:15 PM
Aftrmidnite
Its got something in there thats the thickness of a Disc that keeps rolling around or a defective, dirty Disc detector, tripping it into the play mode. Since I've never heard of a Disc detector going bad in indicating a Disc is there when one isn't. (When they go bad they indicate NO Disc Detected!!) So I would look into a CD player cleaner or a foreign object in the player.
Old Oct 13, 2003 | 04:58 PM
LLENFLORIDA
IF I TURN THE RADIO ON,AFTER LESS THEN HALF A MINUTE,IT SAYS IN THE DIGITAL WINDOW CD IS ON,AND IFTHE RADIO IS OFF.IF I DON'T PLAY THE RADIO,THE TIME STAY'S ON ,BUT THE CD PLAYER GOES ON.
Old Oct 13, 2003 | 07:30 PM
HandOfGod's Avatar
HandOfGod
probably something burned up or crossed in the deck, send it into ford, see if they'll do anything for you, i dont know. or hit a stereo store, usually they have extra factory decks that people have taken out when upgrading, you could get them pretty damn cheap
Old Oct 13, 2003 | 09:36 PM
LLENFLORIDA
THANKS ANYWAY,FORD DEALER IS TOO EXPENSIVE,I'LL TRY THE LATTER.
Old Oct 20, 2003 | 08:23 PM
TheRadioMan's Avatar
TheRadioMan
The problem with the cd assembly is a a small black arm about half a centimetre long that triggers a sensor, pull the cover of the radio bent slightly bend the metal bracket and ur back in business
