1969 power steering
Old Oct 18, 2008 | 12:28 PM
blazer350's Avatar
blazer350
1969 power steering
i have a 1969 f-100 stright 6 240 with manual steering what is evolved in putting in power steering. someone told me its just a swap of the steering box but that just dont sound right to me.
Old Oct 18, 2008 | 12:50 PM
jowilker's Avatar
jowilker
Blazer, If you use the better Saganaw Ford gear, you will need a shorter column to match. You can harvest both from a donor truck through 79 and they will bolt right up.
John
Old Oct 19, 2008 | 09:30 PM
marks69's Avatar
marks69
when i did mine it was just swap the boxes then add a pump. i went with the power steering column from ididit, i wanted crome, tilt and they have one made for these trucks. the problem i ran into was my engine has a serp belt setup so i had to use a pump from a mid 80's truck then get custom hoses.
Old Oct 19, 2008 | 11:07 PM
blazer350's Avatar
blazer350
any way to tell if my mine is a direct swap
Old Oct 20, 2008 | 05:28 AM
jowilker's Avatar
jowilker
blazer, mark's engine was transplanted, there were no trucks with serpentine belts in the year era of this forum including your 69.
You will need to find a donor truck to 79 with a I6 and power steering for your parts. Most of us upgrade to power disc brakes at the same time.
John
