Want cap need help please
Old Dec 21, 2018 | 03:31 PM
Jj Gusho's Avatar
Jj Gusho
I have a 2019 F250 6.7L diesel crewcab with 160” WB and I want to add a cap. It fit in garage with a 83” clearance now but will it still fit with a cab height cap? If not what’s the minimum clearance I need? My drive way slopes down from garage slightly. Also any suggestions on caps would be appreciated
Old Dec 21, 2018 | 03:50 PM
ShadowGrey's Avatar
ShadowGrey
Measure from the bed rail to the top of your cab, then add that to the measurement from the floor to the rail top at the end of your bed. That is the height of a straight top at cab height...Hopefully it is less than 83 inches. If you go to a camper shell place they will show you ones that will fit and probably some that will not...then shop around if you don't like their price.
Old Dec 21, 2018 | 06:29 PM
seville009's Avatar
seville009
You can buy caps that go higher than the cab, in which case it probably won’t fit into a standard garage.
omanalansan
Feb 26, 2025 05:04 PM
Serapis
Apr 7, 2011 07:48 PM
Andy63
2009 - 2014 F150
Jul 29, 2009 12:42 PM
KyThunder
1983 - 2012 Ranger & B-Series
17
Feb 12, 2007 06:12 PM
Flozzie
Apr 30, 2003 09:36 AM
