Sponsored by: Real Truck
V10 with p0357 code
Old Dec 20, 2018 | 11:56 PM
captdean's Avatar
captdean
V10 with p0357 code
I have a 2001 , f250,4x4, v10, 5 speed, 360,885k miles, no cat just straight pipe with muffler. I have a p0357 code that I can't find what's causing it. I've had truck at 2 different shops already. Parts that have been replaced as listed
10 coils
10 plugs
ecm
still get no ground signal to #7 coil.
Do you know of anything else I need to look at. I read here one guy change crank shaft sensor and that cleared his codes.
Also the A/C did blow warm air then started blowing cold. Seems like the misfire is coming and going.
Old Dec 21, 2018 | 08:27 AM
johnfist's Avatar
johnfist
Sounds like you have a wiring issue more than anything. Did you also replace the boots when you did the coils?
Old Dec 21, 2018 | 10:52 AM
projectSHO89's Avatar
projectSHO89
What he ^^ said. Did anyone ohm out the wire between the PCM and the #7 COP connector?
Old Dec 21, 2018 | 11:51 AM
captdean's Avatar
captdean
Yes new boots, wire ohm out good.
Old Dec 21, 2018 | 02:15 PM
projectSHO89
Then it should be working.
Old Dec 21, 2018 | 04:08 PM
captdean's Avatar
captdean
I sent the pcm back to get reflashed, should be in tomorrow. The shop said pcm is not sending signal out to coil.
Old Dec 26, 2018 | 06:32 PM
captdean's Avatar
captdean
Update:
After getting 2nd PCM in, Truck is running fine. Also changed 6 of the coil connectors that the clips had broken off..
Hope to be hitting 400k miles in the upcoming year.
Firefighter 1406
Mar 3, 2014 05:40 PM
Cactus Jack
Modular V10 (6.8l)
26
Jul 20, 2012 08:02 AM
TommyR
Modular V10 (6.8l)
May 5, 2009 04:13 AM
theswagg
Aug 25, 2008 12:38 AM
