10 gallons. Really?
Old Dec 20, 2018 | 11:24 AM
rdayt's Avatar
rdayt
10 gallons. Really?
My truck has a single tank. When I fill it the gauge goes from E to F with only 10 gallons.
The gauge doesn't jump, isn't erratic, smoothly goes from E to F.
I'm tempted to just drive it to see how far it will go on empty.
Any ideas?
Randy
Old Dec 20, 2018 | 12:08 PM
Conanski's Avatar
Conanski
Depends what size the tank is, if it's a 19 gallon you could go almost twice as far before it runs out.
Old Dec 20, 2018 | 12:17 PM
sandymane's Avatar
sandymane
Any ideas?
Randy
Some one may have put the fuel pump from the smaller Ford tank in your tank?????? Float level thinks you are empty. Sandy
Old Dec 20, 2018 | 05:47 PM
FLgargoyle's Avatar
FLgargoyle
I may have a similar problem with my new-to-me '95 4WD. It was down to 1/4 tank, yet it only took 8 gallons. After I filled, it, it showed 'full'. I'm going to carefully drive it as low as I dare, then fill it again. I might even drive with a jerry can of gas just to see.
Old Dec 20, 2018 | 05:58 PM
Veltech's Avatar
Veltech
On both tanks on my truck I can drive 150 miles after I hit e. Best fuel gauge is just off
Old Dec 20, 2018 | 07:47 PM
ifrythings's Avatar
ifrythings
My rear tank is exactly like this but my front tank is accurate. Only thing with mine is I used a tank from an 87 truck to replace the one in my 95 (both diesel so I didn’t change the sender), weird thing is it read right in the 87 but won’t in the 95, everything I can find says they should be the same ohms and should work but it doesn’t work right.
Old Dec 21, 2018 | 12:12 PM
tjc transport's Avatar
tjc transport
i ain't rite
my 88 diesel has been like this since i picked it up with 4 miles on it. i just fill it up when it hits empty. if i was out on a long run, i would fill it up every 250 miles.
Old Dec 22, 2018 | 02:54 AM
TobyB's Avatar
TobyB
Yup- "E" seems to indicate 'less than half' for my trucks, too.
I have run them dry (dual, so pretty low- hassle) and if it reads "E" at 140 miles,
it always makes it to at least 220 before it actually starts to suck air...
go figure,
t
Old Dec 22, 2018 | 08:57 PM
sandymane's Avatar
sandymane
Any ideas?
Randy
If you have a short bed and your one tank is in the rear above the spare it is 18 gallons. If you have the side mount tank it would hold 16 gallons. Sandy
Old Dec 23, 2018 | 05:37 PM
TexasGuy001's Avatar
TexasGuy001
It seems to be pretty typical for the fuel gauges in our trucks be slightly inaccurate. I think this is true of most vehicles, at least that we've had anyway. I'd just be happy the gauge works at all. Seen plenty that don't.
Old Dec 23, 2018 | 08:38 PM
mountainkowboy's Avatar
mountainkowboy
Both my front and rear take 14/15 to fill from empty, I have ALOT of reserve.
mcali2
Mar 15, 2016 05:26 PM
leebolinsky
Sep 14, 2012 01:01 AM
rhopper
Aug 15, 2011 06:25 PM
Mr. Marauder
Sep 17, 2010 07:53 AM
82POS
Dec 8, 2004 03:14 PM
