Inaccurate gas gauge solution
Old Aug 15, 2011 | 06:01 PM
rhopper's Avatar
rhopper
I've noticed that my nice new VDO gas gauge was not very accurate in telling me how much gas I had in the tank. I checked power, ohms, grounds and float travel. The first 3/4 of the tank would go pretty quickly, then the gauge would show 1/4 with 10 gallons still left in the 20 gallon tank. Then it dawned on me. The gauge shows the LEVEL of the fuel in the tank, not the amount. The tank is narrow at the top and wide at the bottom. The first 3/4 of the tank goes faster because the top of the tank holds less fuel. Half the capacity is in the bottom 1/4 of the tank. I guess I'll be driving around with "1/4" tank alot.
Old Aug 15, 2011 | 06:25 PM
badger_hound's Avatar
badger_hound
A similar problem came up on car talk a while back. They were trying to figure out how to use a stick to measure how much fuel was left in a horizontal cylindrical tank. The solution was a little complicated, and relied on realizing that level and volume were two different things, as you indicated above. Here's the gory details:
Car Talk | Doing the Math
mcali2
Mar 15, 2016 05:26 PM
73FOMO
Oct 6, 2011 04:35 AM
Mr. Marauder
Sep 17, 2010 07:53 AM
PhilcoPGM
Sep 17, 2005 07:26 PM
82POS
Dec 8, 2004 03:14 PM
