2018 SD Keep getting shocked
Old Dec 19, 2018 | 05:27 PM
Jakelilly520's Avatar
Jakelilly520
Every time I get out of my truck I get shocked. I haven’t done anything electrical to the truck at all. I have put new running boards on the truck but I don’t think that would have anything to do with the issue. Has anyone experienced the same thing?
Old Dec 19, 2018 | 05:32 PM
CBEllis's Avatar
CBEllis
I’ve had my 6.7L CC SRW for 15 months now and I’m still shocked every time I clean her up...what a rig 😉
Old Dec 19, 2018 | 05:34 PM
RONMCHUGH's Avatar
RONMCHUGH
Romcjr
Just when it's cold . Maybe static electricity ?
Old Dec 19, 2018 | 05:38 PM
SportCustom's Avatar
SportCustom
Under what circumstances do you feel this shock, what are you touching? You might also try unplugging the inverter that feeds the 120V outlets to see if that makes a difference.
Old Dec 19, 2018 | 05:40 PM
Jakelilly520
This is my first brand new truck and I get that same feeling everytime I see it haha
Old Dec 19, 2018 | 05:47 PM
hollygreenman's Avatar
hollygreenman
My bet: static electricity. Gets that way in the winter when the humidity gets real low. It's from sliding your *** across the seat upon exiting.
Jakelilly520
Normally it’s my leg but I don’t think it would static electricity, I’ll try unplugging the inverter and see if that resolves the issue.
Old Dec 19, 2018 | 06:17 PM
Imadentguy's Avatar
Imadentguy
Payment showed up in the mail today.... opened it.... i was shocked........
Old Dec 19, 2018 | 06:28 PM
blueglide's Avatar
blueglide
Check for tight battery connections? Maybe a loose ground causing it?
Old Dec 19, 2018 | 07:42 PM
hindy's Avatar
hindy
Do you have cloth seats? It happens in my F-150 with cloth seats mostly all winter.
Old Dec 19, 2018 | 08:22 PM
FishOnOne's Avatar
FishOnOne
Welcome to static electricity. Simply grab the door as you exit you exit the truck and you won't get shocked.
Old Dec 19, 2018 | 08:52 PM
crewzer's Avatar
crewzer
Winter in AZ is typically rather dry (low humidity), so I too am thinking static electricity. What’s your truck’s seat material, and / or is your clothing material substantially synthetic?
Regards,
Jim / crewzer
Old Dec 20, 2018 | 07:00 AM
H-D Dad's Avatar
H-D Dad
If you have cloth seats, spray static guard on them. Good luck.
Old Dec 20, 2018 | 07:08 AM
HST's Avatar
HST
I had that happen on my previous 2015 F350 6.7L also. Every time I would exit the truck and grab the door handle I would get the shock on my hand. I never could figure out what was causing that. I have had a 2018 and now a 2019 and so far no shock.
Old Dec 20, 2018 | 07:19 AM
eryoung's Avatar
eryoung
exact thing I was thinking, happens to me in the winter with the dry air. I have cloth seats.
