Remote Start "Pit Stop Mode"
Old Dec 19, 2018 | 11:27 AM
hookd's Avatar
hookd
After reading through the forums and forscan sheet I don't see where this has come up before. I have a 2018 XLT with Remote Start and I am hoping there is a way to keep the truck running and remove the key. Aftermarket Remote Start companies call this "Pit Stop Mode" and would be very useful here in the frozen north (ok its 50 degrees today but winter is coming sometime lol). I looked at the secure idle option but it looks to me that only works for pushbutton start. If anyone has any ideas I would appreciate it.
Thanks!
Old Dec 19, 2018 | 11:44 AM
Turbo Dog's Avatar
Turbo Dog
I just set the remote start time to 15 minutes...that's long enough for winter in WY. After that I have to put the key in to keep it running.
Old Dec 19, 2018 | 12:01 PM
KCRebel's Avatar
KCRebel
Thanks!
I haven't noticed that feature either but here's a thought? If you have the door keypad buttons can you lock the keys in the truck with it running use the keypad on the door then unlock when you return?
On my old Mercury Mariners I had for work vehicles years ago I removed the fob from the key and left the key in the ignition and used the fob to lock and unlock the doors. Obviously that wouldn't work today with the fob being made into the actual key.
The aftermarket pit stop system is very nice. My installer called it the coffee stop setting. Lol.
I will say the Police mode is a no go for me because there are times when my wife and I are together with only one fob. Wrong person gets out and you're screwed if you are dropping someone off at the door of the mall or whatever. I disable the double horn honk and the DIC reminder is nice letting me know I don't have the key so I know not to inadvertently shut down the engine. I wish there was a way to override the idle timeout without full police mode in forscan. I'll make a request for the pit stop mode as well. Never hurts to ask right?
Old Dec 19, 2018 | 12:02 PM
screwy's Avatar
screwy
Thanks!
I know what you are talking about. I've never seen a way to do this with the factory system, best you can do is just restart it with the remote as you walk away.
Old Dec 19, 2018 | 12:05 PM
ford390gashog's Avatar
ford390gashog
No way to do it without push button start and secure idle enabled.
Old Dec 19, 2018 | 01:11 PM
hookd's Avatar
hookd
That's what I was afraid of but I was holding out hope a forscan expert had figured it out. I'll read up on how to use the keypad option.
Thanks!
Old Dec 19, 2018 | 03:48 PM
mhoefer's Avatar
mhoefer
try this, when the truck is running with the key in it, try doing the start sequence. Wait a sec, then remove the key. Thats how my older astrostart worked. If not, shut off, remove key, walk away, hit that remote start before around the corner and she will be running when back. Also, 15 minute setting can be exapanded to 1/2 hour by restarting the remote once its running on the remote, it extends the run time to 30 minutes, but just shows 15 minutes in the dash section. I dont know for sure this will work, but its worth a try. Secure mode wont do what you want.
Old Dec 19, 2018 | 03:53 PM
BillyE's Avatar
BillyE
I lock and unlock with the door keypad. That's the best option I have found.
tjc transport
6.2L V8
Oct 16, 2017 12:47 PM
90pioneer
6.7L Power Stroke Diesel
Oct 4, 2017 08:51 PM
hldr
Mar 23, 2017 10:34 PM
LucasMN
1997 - 2003 F150
Oct 12, 2012 10:36 AM
jerryrwoods
2009 - 2014 F150
Dec 17, 2011 09:54 AM
