More horses!!
Old Dec 19, 2018 | 08:44 AM
61ferd's Avatar
61ferd
More horses!!
I have a 1961 ford f100 unibody long box. Its got a 351w (2barrel carb) out a 75 Mercury Montego(only makes a sad 160hp). I'm looking for any good affordable ways to gain more horsepower. I'm open to any suggestions you give me
I have a 4 barrel Edelbrock intake also just sitting around in my garage
Old Dec 19, 2018 | 09:02 AM
rla2005's Avatar
rla2005
Define "affordable". What is your budget?
How mechanically inclined are you? Tools, place to work on the truck, daily driver, etc.?
Old Dec 19, 2018 | 10:09 AM
Tedster9's Avatar
Tedster9
If money is tight, and even if it isn't, put your smart cap on and start studying about ignition timing and the distributor itself, how it works. There's a ton of stuff online. There is a whole bunch of potential to be had simply by modifying the ignition timing curve, the mechanical advance. It doesn't cost anything, other than your time. Need a timing light and maybe a couple bucks worth of springs. Here's a pretty good page on what to do in general.
"Do you want to unleash the hidden horsepower and make full use of the fuel efficiency inside your engine? We can get there by accurately tuning your engine."
http://www.squarebirds.org/simplyconnected/390Build/Distributor.htm
Old Dec 19, 2018 | 10:53 AM
61ferd's Avatar
61ferd
Sweet I´ll look into this. I'm always open to spending some time with my truck thanks for the link!
Old Dec 19, 2018 | 10:59 AM
61ferd's Avatar
61ferd
My max is about $1200 dollars. I myself am still learning things but can do just about anything with the proper guidance, but I have some friends who know these old ford motors like the back of there hand that always are willing to help me. My tool situation is pretty decent, we are no speed shop by any means but we have just about every tool we would need but a welder(if needed).
Its also not my daily as I live in Wisconsin and the winters would destroy the truck
Old Dec 19, 2018 | 01:08 PM
Conanski's Avatar
Conanski
Heads, cam, intake and exhaust are where the gains are, and of those the single biggest bang for the buck will be a cam change. $200-$250 for a flat tappet cam/lifter package and some gaskets could produce as much as 100hp depending upon the cam specs and the condition of the exhaust system. This assumes free labor of course.
Old Dec 20, 2018 | 08:52 AM
61ferd's Avatar
61ferd
Yes, I'm gonna be doing the work myself so no labor costs. is there any specific companies you'd recommend to use. Also what gaskets are you talking about? I'm not the most knowledgeable in this field so if you could elaborate a little thought would be nice
Old Dec 20, 2018 | 09:29 AM
Conanski's Avatar
Conanski
To do a cam change the motor has to be stripped bare, remove valve covers, intake, water pump and timing cover so you need all those gaskets.
Old Dec 20, 2018 | 05:16 PM
baddad457's Avatar
baddad457
Felpro gaskets are about the best to use. Except for their Print-O-Seal line. (also called P.O.S. for a reason) You will need what's called a "full set" But sometimes you'll get the POS head gaskets in these. I would by a timing gasket set and an intake manifold set and a pair of their #9333 head gaskets. You'll also need a pair of valve cover gaskets. Most times cheaper to buy the full set and see what the head gaskets are then decide if you want better head gaskets than to buy all the rest separately. There will be more gaskets in the full set than you'll use, but don't toss the extra stuff, you never know when that stuff comes to the rescue later on.
‘66 F100 Pearl
Feb 18, 2019 03:30 PM
alans77crew
Aug 8, 2010 01:03 PM
jgedmin
16
Jun 28, 2010 05:24 PM
Paco_Jones
Oct 15, 2009 07:43 PM
dutchlincoln79
Feb 28, 2008 04:42 PM
