need some help on a front end conversion.
Old Dec 19, 2018 | 01:41 AM
Ryan Bliss's Avatar
Ryan Bliss
Ok I have a 1989 f150 with the 5.0 in it. I however hate the way it looks and am in love with the front end of the 1979. How would I go about swaping the front from the 1989 to the 1979. Idc about widening or anything I’ve made the interior more modern.
Old Dec 19, 2018 | 06:07 AM
caravaggio2000's Avatar
caravaggio2000
Wouldn't you have to swap the bed too?
Old Dec 19, 2018 | 06:14 AM
Ryan Bliss's Avatar
Ryan Bliss
I honestly just like the grill and the square headlights. That’s really what I want so I figured swapping front fenders hood and grill
Old Dec 19, 2018 | 06:27 AM
caravaggio2000
I'm not 100% sure, but I don't think the body lines would match up front and rear.
Old Dec 19, 2018 | 07:21 AM
bulldogcountry1's Avatar
bulldogcountry1
Are you sure you mean a 79?
Old Dec 19, 2018 | 10:09 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
I'm 100% sure, it cannot be done. NONE of the sheet metal from a 1973/79 will match up to a 1987/91, nor can it be bolted onto a 1987/91.
1973/79's have a concave scallop line (referred to as a "dentside") that runs the entire length of the body sides, while 1987/91 body sides in the same area are as flat as Kansas.
Ford changed the frame in 1980, so none of the engine compartment parts from a 1973/79 will line up with a 1987/91.
If the OP likes the look of the 1978/79 "fish mouth" front end, he should just buy a 1978/79.
Old Dec 19, 2018 | 04:11 PM
tlrtucker's Avatar
tlrtucker
Same question here. Might was well swap in a Camry front end...would look like garbage, IMHO
Old Dec 20, 2018 | 12:48 AM
buckin69bronco's Avatar
buckin69bronco
OP, I think you want to swap to a early 80’s front end. This has the square headlights you are talking about and the body lines would match up.
Old Dec 20, 2018 | 09:11 AM
hivoltj's Avatar
hivoltj
I am with you on strong dislike for the bullnose; they are terrible. With enough cutting and welding anything can be made to fit. Stop and ask yourself if it should be done. Sell your truck and buy a dentside.
Old Dec 20, 2018 | 11:22 AM
NumberDummy
What the hell are you talking about? The body lines will not match up!
Upper pic: Notice the 1973/79's concave scallop line that runs the length of most of the upper bodyside.
Lower pic: Where is the scallop line on 1980/84 (1985/86 is the same, but the mouldings are different)? No see um. The upper bodyside is a flat as Kansas.
1980/86 is an entirely different truck including the frame than 1973/79, not one piece of sheet metal interchanges.
1973/79: The hood sits above the front fenders. 1980/86: The hood nestles between the front fenders.
It's hard to believe that someone that has been a member of FTE for 8 years doesn't know the difference between 1973/79 & 1980/86.
Old Dec 20, 2018 | 05:20 PM
Dave145's Avatar
Dave145
As others have said, it's not a feasible swap. Recommended action is to sell the bullnose and buy a 78-79 truck instead.
Old Dec 20, 2018 | 05:24 PM
1985 Bronco's Avatar
1985 Bronco
The OP has 89 F150. Buckin69bronco is suggesting that the OP install an 80-86 front end, which will bolt on and the body lines will match up.
The 87-91 body style that the OP has is referred to as a Bricknose
Old Dec 20, 2018 | 06:24 PM
NumberDummy
When 1980/86 front fenders are installed on 1987/91's, the body lines do not match up. Try it, you'll see what I'm referring to.
Old Dec 20, 2018 | 06:37 PM
jimlj's Avatar
jimlj
With enough fab work and Bondo, anything is possible. Don't mean you should.
Old Dec 21, 2018 | 01:27 PM
1985 Bronco
I did try it. I put an 80-86 front clip on my 95. It works on 87-91 too. You need to change the quarters/box to match too. The front clip bolted right on. The only modifications I had to make was to the lower fender mount and the bumper mounts. 87-91 trucks even share the same frame horns/bumper mounts as 80-86, so the OP would not have to modify those.
