390 FE Pistons
Old Dec 17, 2018 | 06:54 PM
Tex51's Avatar
Tex51
Talking 390 FE Pistons
I got in the wrong area with this post and just found my way here. I got a 390 FE .030 over and want to put some higher compression piston in my 1969 truck engine. I read some where in here that I should use car piston that I would get better compression. I will be running edelbrock aluminum heads and intake. Hope to fine tunnel port heads and intake and top it off with a 780 Holley. I now not to count on great gas mileage
Old Dec 18, 2018 | 03:50 AM
85e150's Avatar
85e150
Car pistons with a compression height of approximately 1.77inches. Flat top or dished depending on the other specs and the desired compression ratio.
Old Dec 18, 2018 | 10:16 AM
MIKES 68 F100's Avatar
MIKES 68 F100
what is your desired compression ratio ? they have calculators online to help .
Old Dec 18, 2018 | 06:56 PM
baddad457's Avatar
baddad457
Tunnel Port heads will not work on a 390 block. Valves are too big for the 390's bore size.
Old Dec 18, 2018 | 11:14 PM
85e150's Avatar
85e150
Missed that Tunnel Port comment.
OP needs:
https://www.penguinrandomhouse.com/b...9780895860705/
or other fine publication:
Amazon Amazon
Old Dec 19, 2018 | 05:13 PM
MIKES 68 F100
yes Great book ! helped me tons when building my 390
Old Dec 20, 2018 | 05:20 PM
baddad457's Avatar
baddad457
You also might pull the heads and verify what pistons you have now before buying new pistons. You never know, the previous builder may have given you what you think you want now. The piston tops will tell you what's what at a glance, but you'll need to measure the distance the piston tops are down from the block's deck at TDC to figure what the comp ratio is now
Tex51
Dec 17, 2018 06:48 PM
iammacleod
Aug 3, 2018 08:28 PM
vwfreak
Nov 5, 2012 04:50 PM
dhickey
Oct 18, 2002 06:20 PM
proeliator
May 20, 2001 08:07 AM
