Sponsored by: Real Truck
Rear sliding window - LETS FIX THIS
Old Jan 14, 2019 | 07:25 PM
BjornF16's Avatar
BjornF16
Originally Posted by rockhounds4x4
get it closed and leave it closed, order the new window cable system and replace it, its super easy to install
mine had all the same symptoms, it is eating itself inside the mechanism. mine was totally jammed up inside, the steel cable destroys the plastic drum inside and ties itself in a knot. eventually it will quit moving altogether, of course it will be in the open position when that happens
found a new motor assembly on ebay
It was about $210
Can you point me to the new cable assembly...I have same issue as OP. (I've checked White Bear Lake Ford website and only see their "repair" kit which seems to only be the regulator)
Old Jan 14, 2019 | 08:05 PM
CousinJordo's Avatar
CousinJordo
https://rover.ebay.com/rover/0/0/0?m...2F232972890916
Here’s the link. But at $270, I chose to implement an easy solution for $FREE.99 —— I no longer use the rear window
It’s winter anyway. Maybe I’ll change my mind in the spring. But I’ll tear that thing apart trying to rebuild it before I throw $270 at a part.
Old Jan 14, 2019 | 09:20 PM
Colorado350's Avatar
Colorado350
I personally will NEVER do business with PG again, beyond ****ty CS etc. but this is 80ish less.
https://www.partsgeek.com/gbproducts...ad=47362750812
Another option: https://www.ebay.com/itm/OE-Rear-Pow...250+Super+Duty
Bruin008
Jun 9, 2013 09:56 PM
Big-Red-Lariat
2009 - 2014 F150
Jul 30, 2012 08:18 PM
davecobern
Mar 20, 2010 04:56 AM
BigRed03
Apr 8, 2009 04:07 PM
obxtuna
Aug 28, 2005 11:20 PM
