Power Rear Slider
Old Apr 7, 2009 | 08:14 PM
BigRed03's Avatar
BigRed03
Power Rear Slider
So the power rear slider isn't working too well on my F-250. It is an 2007, just turned over 36,000k, so out of warranty unless I can plead at the local dealer...symptoms are pretty slow opening, sometimes open 1/4 then others 1/2 and others full. Think it must be a motor that controls the cables. Any thoughts on where this motor is and how much a pain in the **** it is to do? Or take to dealer...how much? Thoughts or checks I can do? - Thanks
Old Apr 7, 2009 | 08:28 PM
CoastieMK's Avatar
CoastieMK
I had the same problem. I just picked up a can of white lithium grease, sprayed the cables and then operated the slider back and forth. I did that a couple of months ago and haven't had a problem since.
Old Apr 7, 2009 | 08:40 PM
BKB's Avatar
BKB
usally the glass comes unglued from the track. when you open and close the window see if you notice the window getting cocked in the track.
Old Apr 7, 2009 | 10:55 PM
04redstroker's Avatar
04redstroker
I used wd40 on my drivers window, but lithium grease would probably be better. i sprayed th track real good too
Old Apr 8, 2009 | 04:07 PM
BigRed03's Avatar
BigRed03
That white lithium grease did the trick! Problem solved. Thanks for the input...feel like I just made the connection on the Mr. Obvious show (Bob&Tom Show)
