03 Oil Filter
Old Sep 27, 2003 | 08:54 PM
daveplot's Avatar
daveplot
03 Oil Filter
Today I decided to save myself 20 bucks and change the oil myself. How in the world do you get up to the oil filter? My old 98 was soooo easy to do.
Old Sep 27, 2003 | 11:39 PM
Andy-Expy03's Avatar
Andy-Expy03
I saw it take two people. One on the bottom holding the wrench. One on the top applying the force. Didn't look like any fun.
Old Sep 28, 2003 | 08:09 PM
austinjorg's Avatar
austinjorg
Took the plastic plate off that prevents dripping on exhaust and got to it easy with a pair of channel locks.
BTW, no problem since 1st change, hercules put it on at the factory.
Old Sep 29, 2003 | 07:15 PM
expydave's Avatar
expydave
My 98 with remote filter was so easy, but my 03 was a bitch for the 1st filter change. After that its still an easy one person job laying underneath the beast.
Old Sep 29, 2003 | 07:20 PM
daveplot's Avatar
daveplot
That's good. I'm probably going to try it tomorrow. I paid Ford $35 to do it the first time, since the truck was in there for a few "issues" anyway.
Old Sep 30, 2003 | 01:39 AM
tkd's Avatar
tkd
On my first oil change on the 03, I ended up having to refill it and take it to a local shop without getting the filter off. The shop used something resembling a strap wrench except it looked like a seatbelt for the strap and the handle was about 18" long. It still took two guys to get it off. The filter actually twisted and crushed before it came loose. Since then, it's been my hands only with no problems. The one complaint is that it seems to drip a lot when you take it off. I could do my '02 with no drip shields.
Old Sep 30, 2003 | 04:52 AM
haroutd's Avatar
haroutd
From: I'm lost somewhere in NJ -- can someone please find me?!?!?!?
How do you guys feel about changing the filter without draining the oil? Reason I ask is I convinced dad to switch to Mobil1 on his Expedition, and told him he could run it for at least 6,000-8,000 miles as long as the filter was changed in the middle of the run. So, as you can probably assume, I have now encumbered the undaunting task of changing his filter. Can this be done without spilling every last drop of oil out of the filter mechanism? Or should I hook-up the wet/dry vac to the hole where you normally add oil, hoping the suction will keep the oil from draining out the filter hole. Any toughts would be appreciated. I'd rather do this in the driveway myself (I have a nice set of drive-up ramps that would help with the task) than take the truck to the oil change place for something this simple. But if it's going to make a big mess.... I'd rather let them get dirty
Old Sep 30, 2003 | 09:03 AM
wacnstac's Avatar
wacnstac
I do mine from below. Use rubber gloves and two hands. As one posted said, after the first change if they are only put on hand tight it should come off no problemo.
Old Oct 6, 2003 | 08:21 PM
FiremanRon's Avatar
FiremanRon
So, what is the deal with putting the oil filter on with 200 ft-lbs of torque? I didn't have a strap wrench, so I improvised with a pickle fork, a nylon strap and a pipe wrench. And the oil deflecter thingy didn't work so hot either.
Old Oct 7, 2003 | 01:40 AM
Monsta's Avatar
Monsta
Sit. Stay.
I would like to thank you all for convincing me to have the weenies at my local Dealer do my oil changes.
Sounds like more trouble than its worth in savings...
Old Oct 7, 2003 | 01:30 PM
rameyer's Avatar
rameyer
I have done four changes on my '03 Eddie Baur 5.4 4X4 with no problems. In fact I thought it was pretty easy. Is there something different on the other models?
Old Oct 7, 2003 | 02:47 PM
wacnstac's Avatar
wacnstac
The oil deflector thing works alright! It deflects oil in every direction possible but not in any one particular direction.
