Ground wire
Old Dec 13, 2018 | 04:44 PM
daltonjamesadams's Avatar
daltonjamesadams
Ground wire
1966 f100 240, black ground wire fastened to firewall driver side of center, pulled loose from the engine (i guess) where does it go?
Thanks
Old Dec 15, 2018 | 06:03 AM
daltonjamesadams
Its near the pinch weld for the firewall & floorboard.
Old Dec 15, 2018 | 06:15 PM
FuzzFace2's Avatar
FuzzFace2
It may not hurt to run one from motor to the frame if you don't have one.
From the factory my 81 F100 w/300 six runs from the battery to frame then to starter bolt to ground motor / trany.
There is also an 8ga wire ground from the motor to the fire wall to ground the body.
Can never have too many grounds
Dave ----
Old Dec 15, 2018 | 07:52 PM
daltonjamesadams
That is about the size this wire is. If i cannot find the original location i will probably put it under a bell housing bolt.
crazyrwe
Nov 10, 2012 05:19 PM
daningraham
Nov 6, 2010 10:06 PM
SlickFreak
Mar 1, 2010 02:12 PM
james G. phillips
Jul 17, 2008 05:16 PM
spiritwild
Bronco II
Jul 19, 2006 07:54 PM
