This morning on my way to work my tailgate mysteriously opened and I lost a box of Christmas presents headed to UPS. I don't know if this is the same issue as previously reported (I don't recall complains of the tailgate opening from a moving vehicle) or something about the keyfob in my pocket. Regardless, I can't allow this to happen again.
Has anyone ever rigged up a mechanical lock for the tailgate? I'm thinking of running a butterfly anchor into the unused bed extender hole and roping that off to the boxlink anchor. Any other ideas?
Do a search here and there's lots of complaints about it just opening on its own. Its a stupid feature. Some have tied it off, others have just unplugged the actuator so you can't accidently open it no matter what.
It shouldn't allow it to open while driving - via the key fob or panel button. So sounds like the mystery opening we've read on other threads. While anchoring it will stop it from happening, its a bummer if it cannot be fixed. That one time you forget to anchor it and you may lose stuff again or in my case the entire tailgate.
I am not sure if it happened to me or if someone was a good thief. Have a topper on my bed and my tailgate got stolen. No damage to vehicle or topper, so always left me wondering if it did a mystery drop and someone jumped at the opportunity.
For those wondering a platinum 350 tailgate with the ladder, camera and all the bells and whistles was written up for ~$5k to replace from my insurance company. The part number for the ladder alone was $980. Crazy.
Not a "stupid feature" at all, when it works correctly. Absolutely love it when hooking up my 5er. I can get close with the gate closed so I can use the camera to see. Then drop it and continue visually when close to the hitch. A very convenient feature.
For the record, mine works fine with 6k on the clock.
Troy
I took Tricon's comment as 'the ability to open it remotely' is the 'stupid feature', if so, Tricon, I agree...cameras can be had without that feature...
Again, I dissagree. Having the camera is not the issue. Being able to push the button and release the gate so it falls and I can continue without stopping is a big bonus. Having to stop, put in park, apply ebrake, get out, lower gate, get back in, put in R, release brake, and contue was fun years ago.
Troy
Troy
Sorry, I misunderstood, but I am good to get out and turn a key.
There is no key unlock on my tailgate, atleast if there is I have never used it, so if you disconnect the actuator, your fubar'red for letting down the gate from the button on the gate? I am on my 3rd winter, 42,000 Km, never have I had a mysterious drop of the gate, I have hit the button, and reconsidered because the garage door was still down, but never unexplained. Like the doors, it would actually be really good to have a "door adjar" alarm on the dash so you know the gate went down. then you would know to at least look..... With my cover on the box, I cant see if the gate is down....
I guess I assumed the tailgate wouldn't drop remotely while the transmission is in drive, but hey if it's just going to be random anyway, why not.
It's not whether or not the tailgate is allowed to drop when the truck is moving (you actually can't drop it with the doors locked either), it's a short caused by water in a wiring harness connector under the bed of the truck. Gremlins like that pay no attention to rules... The service bulletin for this problem is to replace the whole wiring harness. Mine is in the shop for just that procedure now.
Troy
There’re several previous strings on this issue. Water is getting into the connector next to the spare tire. Unplugging the connector, letting it dry, and filling with dielectric grease fixed the problem. Haven’t had this happen since doing that.
Going to pick it up now. They said they checked all the connectors and they were all tight and dry, so they couldn't replace the wiring harness under warranty. It's only happened about 4 times in 2 years so my issue must be something else... Racking my brain trying to figure out what might have been a common denominator each time it happened.
