Is there a market for NOS stripe kits? I've read the glue only has a shelf life of 2years but they still seem to be in good shape for a pattern or someone to reproduce. I have these two kits: D7TZ-1320000-AU
Stripe kit, tan
Consists of back panel, upper and lower
And
D6TZ-1020000-AJ
Brown
Is this worth holding onto and selling or should I just toss em back on the shelf to collect dust for 40more years lol
D6TZ-1020000-AJ .. TYPE 6 1976/77 Regular Cab BROWN Bulk Tape Stripe Kit / 25' roll, 3/4" wide / Obsolete
D7TZ-1320000-AU .. TYPE 8 1977 Explorer Regular & Super Cab TAN Stripe Kit / Consists of upper & lower back panel / Obsolete
Neither by now will be any good.
Over time, the outer stripe layer becomes adhered to the inner adhesive layer, so when you attempt to peel the stripe layer off, some/all of the adhesive layer will come along with it.
D7TZ-1020000-AU .. TYPE 8 1977 Explorer Regular & Super Cab TAN - Consists of hood, upper & lower fender & door / Obsolete
Over time, the outer stripe layer becomes adhered to the inner adhesive layer, so when you attempt to peel the stripe layer off, some of the adhesive layer will come along with it.
My kit is D7TZ-1320000-AU which is the back panel upper and lower.
Also I was looking to see if it's something worth selling to someone looking to get them reproduced or if it's not worth the time and I should just toss em.
