General Diesel Discussion
Memory seat problem
Old Dec 13, 2018 | 06:35 AM
Bford12's Avatar
Bford12
Memory seat problem
2017 f250 king ranch 6.7 12k odometer.
Went to get in it today and the memory seat was not functioning.
No matter how many times I pushed the button on the door.
The steering wheel and seat were stuck in the easy exit position.
Was able to adjust seat with the seat controls but the steering wheel wasn’t moving.
I started vehicle and everything ran fine nothing on dash indicating any problems.
Had to drive it withe steering wheel in the easy exit position.
Also noticed my digital speedometer had changed from mph to kph.
I pulled into a parking lot and went into the settings and changed it back to mph.
I started the truck again and the memory seat settings started working again.
What is going on here?
Anyone else have an idea?
Thanks
Old May 7, 2019 | 02:51 AM
Elma asheley's Avatar
Elma asheley
NO idea about it, maybe there is door problem.
Old Feb 18, 2024 | 09:13 AM
jerkus730's Avatar
jerkus730
1st Gear
seats losing memory
Thanks
I had the same problem, it took my dealer a couple months to figure it out. They replaced a wiring harness under the seat that took care of it.
Old Mar 27, 2024 | 12:17 AM
luffy's Avatar
luffy
1st Gear
Thanks for the info
Old Jul 5, 2024 | 02:07 PM
chips34's Avatar
chips34
4wd High
I had a similar issue with my 2018 F250 King Ranch. The memory seat and steering wheel got stuck in the easy exit position, and the digital speedometer switched from MPH to KPH. I just turned the truck off and back on, and everything went back to normal. It sounds like a software glitch or a reset issue. If it happens again, you might want to visit the dealer for a check-up.
BIGTRUCKBIGRV
Oct 29, 2020 09:45 AM
EXv10
Aug 21, 2013 10:47 PM
volfan945
Sep 24, 2004 11:01 PM
