94 4x4 Ranger
Old Dec 12, 2018 | 01:59 PM
Fastronald's Avatar
Fastronald
94 4x4 Ranger
I may buy a 1994 Ranger 4xs4......anything I should know or expect as far as problems? it's a 3.0...………..might think of swapping a Super Coupe 3.8 in it.
Old Dec 12, 2018 | 10:09 PM
phoskins's Avatar
phoskins
Make sure the Super Coupe 3.8 engine will mate up with the transmission in the Ranger. If not, you may need to swap the transmission from the Super Coupe, and buy/find/fabricate some parts to keep the transfer case and 4-wheel drive. It will be a challenging swap, no matter what. Of course, engine mounts and crossmember will need to be bought/made & relocated.
As far as the '94 Ranger goes, get it scanned with an OBD1 scanner on it (may have to take it to a shop) & make sure error codes are resolved somehow. Also, check for rust everywhere, it can be hidden!
Old Dec 13, 2018 | 07:57 AM
ranger pat's Avatar
ranger pat
Veteran: Navy
If you are determined to go with the 3.8, you might investigate using something like 1998-2000 Explorer 5.0L transmission and transfer case which will mate to your engine. I think 3.8 and 5.0 shares the same rear face of block. The transfer case is one speed as opposed to 4H and 4L, but it will package under the Ranger without crashing into the fuel tank.
Old Dec 21, 2018 | 01:03 PM
mbuckley's Avatar
mbuckley
My first truck was a 94 Ranger and it was a good truck. I miss it.
Old Dec 27, 2018 | 03:45 PM
phoskins's Avatar
phoskins
I've had my '94 4.0 V6 2wd since 1999. I've put about 150,000 miles on it, it's now at 207k and needs some work, but I still love it.
Jacobgibson
Apr 5, 2018 09:20 PM
edtahaney
23
Feb 22, 2015 04:27 PM
fmcdoug
Escape & Escape Hybrid
Mar 24, 2008 10:35 AM
krane operator
Mar 25, 2007 05:31 PM
John Perdziak
Apr 28, 2005 10:43 AM
