Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
1964 C600 Possible engine swap
Old Nov 22, 2017 | 09:14 AM
Micah Mitchell's Avatar
Micah Mitchell
1964 C600
I am trying to decode the numbers to figure out what transmission came in this truck originally. The code is an L. It may not have the original trans because I know the engine was replaced. Just curious as to what came with it when it was new.
Old Nov 22, 2017 | 05:02 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
L = Clark model 2651-V1 or 2653-V1 5 Speed Direct.
Old Nov 23, 2017 | 10:27 AM
Micah Mitchell
Thank you.
Old Dec 12, 2018 | 10:24 AM
Micah Mitchell
We have a 1964 C600 that we use on our farm to haul grain. Someone had swapped in a 300 inline 6 at some point. We are considering replacing the gas engine with a diesel. Would a 7.3 idi be a good choice to swap in and what things do I need to consider before doing this?
Old Dec 12, 2018 | 02:29 PM
85e150's Avatar
85e150
Threads merged.
Welcome back to FTE!
As I'm sure you've observed, one big issue with the C series is the shifting mechanism. While you can get that oil burner comfortably nestled into the truck, you will either have to bolt it to the existing trans or another OEM type transmission that incorporates the top cover that accommodates the u-jointed shaft shifter.
You will also have to fabricate mounts, put in a larger radiator, and possibly an entire fuel system, tank and all.
What transmission do you currently have?
Old Dec 13, 2018 | 08:15 AM
Micah Mitchell
We were told when we bought the truck that it originally had a diesel engine in it. I am not sure which engine. The return line for the fuel system is still there just not hooked up at the engine side. I am not sure what transmission is in it currently. It might be the original which was Clark model 2651-V1 or 2653-V1 5 Speed Direct. I can crawl under it this weekend and get some numbers if that will help. I was originally thinking of putting in a Perkins 354 out of a combine but thought maybe the 7.3 would be easier. I would have to hunt down a harmonic balancer for the Perkins.
Old Dec 13, 2018 | 04:10 PM
85e150's Avatar
85e150
Wouldn't that Perkins set a new standard for "slow"? I might rather have the 300 vs. a really slow oil burner. jmo, which is worth less than a gallon of gas, liquid or vapor.
Old Dec 14, 2018 | 05:21 AM
NumberDummy
4th digit of the VIN is the engine code, post what it is.
DSLPOWR
Apr 3, 2019 09:34 PM
BigBlue99
Jun 5, 2015 07:02 PM
Semper Fordelis
Dec 26, 2008 12:40 AM
nlee1188
Nov 1, 2005 10:00 AM
dono
1983 - 2012 Ranger & B-Series
Apr 17, 2002 11:13 PM
