Overheating
Old Dec 10, 2018 | 06:37 PM
Larry04570's Avatar
Larry04570
Overheating
1985 f150 6 cylinder 300 overheating after installing overflow reservoir
Old Dec 11, 2018 | 05:07 AM
FuzzFace2's Avatar
FuzzFace2
How do you know it's over heating?
Dave - - - -
Old Dec 11, 2018 | 07:04 AM
Larry04570's Avatar
Larry04570
Dave - - - -
temp gauge all the way to right pushes fluid into resevoir. If resevoir filled to cold level before it over flows
Old Dec 11, 2018 | 08:12 AM
Franklin2's Avatar
Franklin2
Have just done any work to the engine and have drained the coolant and refilled it?
Old Dec 11, 2018 | 08:56 AM
Larry04570's Avatar
Larry04570
yes drained and flushed coolant only work replaced thermostat
Old Dec 11, 2018 | 09:06 AM
Franklin2's Avatar
Franklin2
I would run it with the cap off the radiator. It may overflow on you a couple of times till finally the thermostat is fully open. Once it is fully open and you see water flowing through the radiator, top it off and you should be good. Sounds like you have air in the engine.
If you want to try to prevent this or minimize this in the future, when filling the radiator take one of the heater hoses off the engine, preferably the higher one. Don't take them off the heater core, too easy to crack that. Then fill it till coolant comes out of the place you disconnected, and then quickly reconnect and keep filling. It will still have some air in it but not as much as it does now.
MONAVIERONJON
Jul 9, 2013 09:55 PM
whitesdford
Jun 19, 2012 05:57 AM
Mr. PC
2004 - 2008 F150
Jul 21, 2010 05:48 PM
RA112222
1997 - 2003 F150
26
May 13, 2010 09:26 PM
fatbob
Jan 26, 2005 10:08 PM
