Twin I_Beam
Old Dec 9, 2018 | 08:40 PM
Dale Boehlen's Avatar
Dale Boehlen
Smile Twin I_Beam
I have a 52 ford rat rod that has a twin I beam front end axles for the late 60's to early 70's truck or van. How do I tell what year the axles and spindles are and what are they from? Thanks
Old Dec 10, 2018 | 01:14 AM
RichS2659's Avatar
RichS2659
Ford parts use an engineering number cast in them that starts with a letter that usually signifies the decade the part was first introduced. Next is a number which is the year. As an example, C7 means 67. Do you have 5 bolt wheels which mean a F-100/150 TIB axles, or 8 bolt? Do you have disc brakes?
Old Dec 10, 2018 | 09:36 PM
Dale Boehlen
It's a 5 bolt wheels and does have disc brakes but could not find any serial numbers at all
Old Dec 10, 2018 | 09:57 PM
Dale Boehlen
I hope you can see the photo's
https://www.flickr.com/photos/102039041@N02/
Old Dec 10, 2018 | 10:35 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Disc brakes introduced in 1973 F100 2WD, 1975 E100/150 & F150 2WD.
The beams have cast ID numbers on them.
Example: 1971 F100 2WD from serial number M00,001 & 1972/74 F100 2WD: D2TA-3008-DA Right & D2TA-3009-DA Left
Old Dec 11, 2018 | 09:47 AM
Dale Boehlen
Thanks for the info, the reason for my question is we want to know what different spindles can fit on the axles. I'm guessing they are 1973 F100 2WD, 1975 E100/150 & F150 2WD axles . We'd like to change the spindles to something better that we can add brackets for a drag link and steering bracket. Are you able to see the pictures Ii posted in the link?
Old Dec 11, 2018 | 10:37 AM
Dale Boehlen
The information we got when we got the rat rod was the previous owner used a parts truck to build this...It has a 351C for an engine which is more like a 1978-1979 F150. We are still researching parts numbers to figure out what it has...The joy of owning a rat rod...lol
Old Dec 11, 2018 | 12:50 PM
NumberDummy
You will not find a single part number marked on a part.
NO F100/150 or any other year truck had a 351C (excepting Australia).
351C installed in 1970/74 Ford/Merc Passenger Cars only!
1977/79 F100/350 available with 300 I-6, 302 2V, 351M/400 2V and 460 4V (except F100). 302 & 460 not available with 4WD
Look for the block casting number and post it. If it's D7TE-A2B .. it's either a 351M or 400 because both use the same block.
NO part numbers marked on parts after 1956, just casting or ID engineering numbers, when applicable.
Old Dec 11, 2018 | 02:35 PM
Dale Boehlen
Hey thanks...guess our Rat rod is more of a Heinz 57 then we thought....
runsky69
Dec 4, 2018 05:18 PM
jcandela00
Nov 27, 2016 01:48 PM
coreychurch
Jun 9, 2007 10:50 PM
66FORDFAMILY
Oct 9, 2001 08:00 PM
