My 77 F-150 with 460 has been hard starting when cold lately. I've think I have found the culprit. When I vacuum tested the Vacuum Advance diaphragm it held vacuum but the advance lever failed to move.
Is there a way to free it up without breaking anything?
That shouldn't effect starting at all just open throttle driving. Couple months ago I tried to get mine free because truck would knock bad going up hills on the highway. Couldn't get the vac advance free and couldn't get apart it was so rusted so got a reman dizzy from napa and 3 miles after installing the counter weights blew apart and sheared the shaft. Got another only this time new and so far so good. Got a Davis Unified on order just in case though.
Do you have points or elec ignition? Also, check the cap contacts. I found that the aluminum ones don't hold up as well as the brass ones and cold wet weather seems to aggravate it more.
I got the vacuum advance to free up with penetrating oil and tapping it gently.
You were right Butcher, it did not effect the cold starting.
I checked the carb and the two squirter nozzles were just dribbling fuel (not squirting).
I cleaned them and had to order new non-stick gaskets. Somehow the one I had stuck.
Anyway, waiting on them and a new steel accelerator pump. I'm pretty confident that was the hard start issue.
Thanks to all of you for your advice.
