Sponsored by: Innova
running the power wire
Old Sep 27, 2003 | 04:48 PM
tayz34's Avatar
tayz34
i have a 94 F-150 and i was wondering were did you guys run your power wire to your amp in your older f -150's thanks for the help
Old Sep 27, 2003 | 08:20 PM
triton_2002's Avatar
triton_2002
You should conect the power wire directly to your battery's positive post, with an inline fuse close by. You can also make the connection at the distrubution box (next to the fuses), but I think this tends to dim the lights if you've got some high power amps and all your accesories are running.
Old Sep 27, 2003 | 11:05 PM
optikal illushun's Avatar
optikal illushun
i ran my power wire along the left side of the truck, drilled a hole in the floorpan, installed a grument and went from there. id take a pic to show but its rainin out...dont forget to install a fuse no more then 18" from the battery and dont use the dist. fuse box.
Old Sep 28, 2003 | 02:35 AM
mikewrt's Avatar
mikewrt
don't connect the amp wire to your fuse block. hook it straight to the battery
Old Sep 28, 2003 | 02:22 PM
tayz34's Avatar
tayz34
ya i had it hooked to the battery w/ the inline fuse and all but i just diddetn now how to get threw the fire wall. i found one whole with a rubber grommit but it seems to be a little bit to tight i might have to grind the inside down or i found a spot to run it under the truck(dont want to do) and bring it in right behind the drivers seat
Old Sep 28, 2003 | 02:49 PM
triton_2002
I'm not familiar with your specified year truck, but just keep looking under the dash area. You shouldn't have to drill any holes, there should be a few spots throught the firewall.
tgossell
Oct 30, 2016 12:27 PM
95Fummins
Feb 23, 2016 10:35 PM
shakenbake254
Feb 19, 2016 06:43 PM
Gary Lewis
Electrical Systems/Wiring
16
Oct 7, 2015 05:02 PM
projectdagger
Aug 25, 2013 02:16 PM
