2002 EB 250 Block Heater
Old Dec 8, 2018 | 02:24 PM
Wandering Bob's Avatar
Wandering Bob
I don't see anything using the search feature, but surely someone must have done this mod.
I have a 2002 EB 250 with a 5.4 triton engine. I've called 2 parts stores looking for a block heater. They both say none is available and suggest I use the type that splices into the lower radiator hose. I would prefer using a block heater. Has anyone done this? I know it's tight in there, but would hope it's possible.
Also, had anyone used the radiator hose type heaters. How well do they work?
Thanks in advance,
Bob
Old Dec 9, 2018 | 05:00 AM
JWA's Avatar
JWA
I've seen all types of engine pre-heaters, the radiator hose being one. I've also seen oil pan heating pads for super cold climates where -20 > -50+ are common.
Personally I'd contact a Ford dealer to see what's available--the hard part there would be installing them in the freeze plug holes. Wiring would be fairly simple, assuming you're handy in that area already.
You might also look at sites where big truck parts are sold (Freightliner, Kenworth etc)---almost certainly they'd have something suitable for your situation.
Old Dec 9, 2018 | 05:13 AM
seville009's Avatar
seville009
Are you saying that your engine is set up to have the block heater, and you’re just looking for the heater element and cord?
Old Dec 9, 2018 | 06:29 AM
Wandering Bob
Sorry seville009,
Yeah, that was confusing. This van was built in CA, moved to MT, but was garage kept year round, now in Alaska. There is no block heater and I feel it's necessary up here.
So, yeah, looking for a block heater to instal into a freeze plug with electrical connection. I know there's not much room in there, But, I'd think there should be access.
Thanks,
Bob
Old Dec 9, 2018 | 06:44 AM
Wandering Bob
JWA,
Thanks so much. I actually had my van sit at a local mechanic's for 5 weeks, wasn't even touched. I didn't push it but then it started getting cold. I called the Ford dealer 3 times and never got a call back. So, you're right, that will be my best bet. I need to try that route again.
And yup, I'm in Alaska, so do think I need to get one installed.
I hoping to find someone that has installed one on an econoline so I can at least save some trouble if I end up doing it myself.
Bob
Old Dec 9, 2018 | 12:46 PM
baddad457's Avatar
baddad457
Might not be enough room in the coolant jacket for a heating element.
Old Dec 9, 2018 | 12:58 PM
seville009's Avatar
seville009
Kat’s makes magnetic block heaters. They’re not that expensive (based on a google search), so maybe give one if those a try on your oil pan. If it works, would be less hassle than trying to install a permanent one.
Old Dec 9, 2018 | 10:45 PM
Wandering Bob
Yup, that's what I'm hoping for.
Thanks
Old Dec 9, 2018 | 10:47 PM
Wandering Bob
Nice! They don't have the best reviews, but would be an easy alternative, at least temporarily!
Old Dec 10, 2018 | 11:56 AM
wiskeyVI's Avatar
wiskeyVI
I had bought one of the element types that was to fit the block, in a specific plug....They were not compatible size wise.
I was going to get one that fit the lower cooler hose. I'm not sure the linkage on the steering stabilizer would clear it.
Old Dec 16, 2018 | 10:24 AM
bashby's Avatar
bashby
Have you looked into the "tank style " heaters. They hook into the heater hoses and I believe the have a circulator pump. That would be the easiest install.
Old Dec 17, 2018 | 12:02 PM
wiskeyVI's Avatar
wiskeyVI
From what I recall, the tank style heaters don't have pumps, they rely on the water moving due to heat.
5.4f250sd
Dec 11, 2010 12:58 AM
bigb9582
13
Oct 10, 2009 07:27 PM
MarkMoore
Modular V10 (6.8l)
Nov 5, 2006 10:22 AM
sturoe
Nov 3, 2006 03:13 AM
Roger_Emo
Aug 10, 2002 10:40 AM
