Sometime's it's just too easy
It started just after I rebuilt the stock Autolite 2100 for my fresh 390 with a hesitation and a miss just off idle, and general poor cold performance unless fully choked.
Checked the float and double checked. Checked choke pull down and double checked. Same for idle mixture, and potential vacuum leaks but still no dice.
So I'm about ready to take a hammer to the carb, but I need fuel so I had down to the gas station. I take off the gas cap, and low and behold there's the problem. Apparantley the gas tank had built up a decent amount of pressure, physically forcing the cap off the filler neck when unscrewed.
Well, wouldn't you know it all the hesitation and missing has been cured. Two weeks spent tweaking and fidling with that darn carb and all I had to do to fix it was unscrew the gas cap.
So anybody else have similiar experiences? Spend weeks trying to fix something that could have been easily solved in a matter of minutes?
after rebuilding the engine twice in one month (thats another story altogather) replacing the tranny 3 times ( yes yet another story) i was finally going to start enjoying all the hardwork i put in, well first time on the throttle the car shut off after 1/8 mile. Then it would come back to life about 30 seconds later. Regular driving this did not happen at all. So for the next 2 months i tore apart the carb and replaced everything i could think of. i was kinda perplexed, i had friends look at it, i had a speed shop run it on there dyno thing and try and get it to do it again, but they never could get it to do what it did for me everytime i tried to get on it. And yes i replaced the tank. So i gave up the idea of ever getting a good time at the local dragway park. fianlly i found a spot of rust in my bed starting to come thru so i decided to fianally get around to removing the old undercoating and redoing it. as i was under the car getting the old stuff off, i found a small section of orignal steel fuel line i never replaced, i didnt see any gas leak or anything, i finished the job, installed new line and went to get on it as i was heading out to the mall to pu my girlfriend. At the usual point she would shut down she just kept going, turns out on closer inspection of the 12 inch fuel line i replaced there was a hairline crack, it wouldnt leak gas, but when hooked up to the compresser i found out it would let air in. So i was getting a air bubble in my line when i was getting on it that was causing my car to shut down and when the air bubble passed it would come back to life. 2 months and 1400 dollars in parts later, oh and by the way, i got a 11:49 1/4 mile at about 132 if i remember right.
its not as cool as opiewans story but i like it
We never had any real class time studying the automotive engine or any other engine for that matter. Our teacher was from the old school and firmly believed in hands on instruction. That he did. He had perfect control over the class. He described in detail every aspect and part function as we went along. Making sure that the least of us understood what we did and what we were going to do next. In the course of a couple of months we felt knowledgeable and proud of the of our accomplishment. The crank was in and the piston/rod assemblies were now to be put in. About the time the third rod and piston were installed. the teacher decided we could finish the fourth and final assembly without supervision. It is here that the project went bad. We lost half of the last rod bearing. We looked all over the place for it and finally Eddie J. says we dont need the dang thing. So he gets out his knife and cuts off a chunk of his leather belt. and after a bit comes up with a neat strip that fits perfectly where the bearing half should have been. We slapped it together and never told the teach. Later when we first ran the engine wierd glances were exchanged amoung us. But I got to say it sounded allright. It got driven back to the farmer,(15 miles or so), and he was pleased with the job. I don't really know how long the leather bearing half lasted.
