Coil Problem on 83 7.5L
Old Sep 27, 2003 | 04:32 PM
havinfun's Avatar
havinfun
Unhappy Coil Problem on 83 7.5L
I have an RV with a Ford 7.5 liter engine. I keep blowing coils. I have replace the ignition module but it still keeps happening.
I have checked the power coming from the ignition and it read 12.0 - 12.5 on the clip. When I attach the clip to the coil it reduces to 7.0 - 7.5. If I start the engine - it bounces all over the place - from 3.5 - 11.5.
Any idea why I keep blowing the coil?
Old Sep 27, 2003 | 04:44 PM
bigjon's Avatar
bigjon
Lightbulb
a little more information guess? this is a thin film ign?
most all ignitions start on 12v and run on 6v and you have
two wires? on the ign circuit? one with a resistance??
Old Sep 27, 2003 | 08:48 PM
havinfun's Avatar
havinfun
From what I can see, the positive comes straight from the ignition to the positive on the clip that goes on the coil. This wire on the diagram shows that it should have a resistance wire. I am not sure how to tell if this wire is working.
I have considered running a new wire to a resistor (the resistance wire is obsolete arording to the parts supply house I go to) and then from there to the coil.
