4 wheel drive shaft super hot ....not in use??
Old 12-07-2018, 02:49 PM
jstihl's Avatar
jstihl
jstihl is online now
So I I was reading through another thread and someone mentions it is a good idea to put the truck in 4 Low (without locking hubs), when backing up a heavy load. It worked great! Then I was driving home towing a heavy trailer and saw that my oil temps were getting up pretty high, around 217 degrees which is not very common for my truck but has been known to to get up there during the summer months. The 4x4 indicator light was still on( sometimes it takes a couple days to go out), so I thought maybe it was still in 4 high and causing more work for the engine and giving me higher oil Temps. I crawled under the truck to see if the four-wheel drive shaft spins freely and damn near burnt my hand! The four-wheel drive shaft spins freely when I am in park so it's not engaged in four-wheel. Does anyone know what would make the four-wheel drive shaft so hot??
Old 12-07-2018, 03:24 PM
Skip1970's Avatar
Skip1970
Skip1970 is offline
wow thats pretty interesting, i never seen that happen
Old 12-07-2018, 03:56 PM
jstihl's Avatar
jstihl
Thanks for the bump skip, I am pretty puzzled by it too.
Old 12-07-2018, 05:00 PM
AllaboutMPG's Avatar
AllaboutMPG
AllaboutMPG is offline
Might be time to check fluid level in front diff
Old 12-07-2018, 05:23 PM
Y2KW57's Avatar
Y2KW57
Y2KW57 is offline
Received 3,409 Likes on 1,789 Posts
Originally Posted by jstihl
The 4x4 indicator light was still on( sometimes it takes a couple days to go out).... Does anyone know what would make the four-wheel drive shaft so hot??
I see a correlation here. I would suggest that you get a friend or spouse to drive your truck slowly while you crouch off to the side, safely away from the truck, crouched down so you can look at your front driveshaft to see if it is turning.
Whenever I shift out of 4wd, my indicator light extinguishes IMMEDIATELY.
Old 12-07-2018, 08:09 PM
jstihl's Avatar
jstihl
I agree, I'm going to give that a shot tomorrow. As far as the indicator light goes, from what I've read that is a common problem for the light to stay on but definitely going to check the drive shaft to make sure
Old 12-07-2018, 08:16 PM
Colorado350's Avatar
Colorado350
Colorado350 is offline
Jason, have you pulled the cover to inspect the gears? Fluid levels good? If you have a IR Gun, I’d throw it in the cab and start checking diff temperatures.
Old 12-08-2018, 11:02 AM
'88 E-350's Avatar
'88 E-350
'88 E-350 is offline
Engine heat may be what's heating up the shaft. If it free spins it's not engaged. The shaft is likely to turn while driving, pretty common, but it won't be at full speed like the rear. Even tho the drive gears to the shaft are disengaged, all the stuff spinning will make the shaft turn when you're driving. It would take a lot of friction in the front drive assembly to raise oil or driveshaft temperatures, I can't imagine that much friction happening anywhere for more than a few minutes without causing an obvious failure.
As for backing in 4low, if you have the stock hubs and the system is working they will engage themselves so beware. I disconnected the auto hub lock system in my '99 so I could do the 4low maneuvering without issues.
Old 12-08-2018, 11:55 AM
PrescottIce's Avatar
PrescottIce
PrescottIce is offline
Sounds like a good application for a Go-Pro and a chalk mark on each driveshaft. Or a borescope camera, they're inexpensive on Amazon and they wifi images to your phone or tablet. A picture is worth 1000 words, but 30fps streaming video is priceless in some cases.
Old 12-08-2018, 12:00 PM
Sous's Avatar
Sous
Sous is online now
Received 4,473 Likes on 2,857 Posts
I did a similar thing when I was diagnosing the clutch chatter my truck was experiencing. The camera mounted under the truck gave me confidence that the leaf springs and traction bars were not the problem.
Old 12-08-2018, 01:27 PM
AllaboutMPG
jstihl I think I misunderstood your first post. Are you talking about the axle shaft or the front drive shaft? My first thought was axle shaft. If it's the front drive shaft did you grab it near the front or closer to the transfer case? could you have a small exhaust leak blowing directly on the drive shaft? Is your transfer case smoking hot?
Old 12-09-2018, 01:13 PM
jstihl's Avatar
jstihl
it's the front drive shaft , it was hot on both ends and from what I remember the transfer case was pretty warm as well but not as hot as the front drive shaft. I haven't seen any exhaust leaks . I tried probably 10 different times to put it in two wheel drive, and it feels like it's in 2 wheel drive but the indicator light stays on. This has been a problem in the past where is the indicator light would go out in a couple of days
Old 12-09-2018, 01:20 PM
jstihl's Avatar
jstihl
I haven't checked the gears, but I had all the fluids changed out when I bought the truck. That was about 2 years ago, 40,000 miles and no leaks. Been raining here most of the day so just waiting for a chance to go check it out. Is the fluid supposed to be about a quarter inch below the top plug?
Old 12-09-2018, 03:17 PM
DieselDenny's Avatar
DieselDenny
DieselDenny is offline
Yep and Yep you should be able to dip your pinky finger in and get a solid result. If needed add specified lube.
If dif and tc readings for lube are good, I suspect your trans is locked. You can always drop the front shaft to isolate the issue.
Denny (check your relays!)
Old 12-09-2018, 03:58 PM
jstihl's Avatar
jstihl
thanks Double D, do you mean it is locked in 4-wheel? My four-wheel is all manual, I'm assuming that there wouldn't be any relays for that right?
Quick Reply: 4 wheel drive shaft super hot ....not in use??
