Adding Seat Belts to the '57
Old 10-29-2018, 05:36 PM
HyePo57's Avatar
HyePo57
HyePo57 is offline
So as I'm finishing up the interior and waiting on the seat belts to arrive (already weeks past est from FL), i was curious as to what y'all did to install the mounting plate above the shoulder ? There really doesn't seem to be a good place to mount this bracket.
seems like there is a big space right where the pivot point would mount... for average peeps.... what say y'all?
here is the plate that comes with the 3 point seat belts for '57-60 f100 from seatbelts plus
and here is where i think it may fit the best... just a few inches above the shoulder so it does not come across the neck (under 6 foot).
I need to fab a plate that curves and sits behind the horizontal braces so it does not interfere with the head liner... prob can rivet into place once shoulder plate is welded on the curved insert
Old 10-29-2018, 11:32 PM
G-Force junky's Avatar
G-Force junky
G-Force junky is offline
I was thinking the same thing but I think it needs some strengthening
Old 10-30-2018, 12:44 PM
MARC's Avatar
MARC
MARC is offline
I used 3/16 flat plate steel stock
The width of the inner curved part. Bent it to match the curve. Welded the nut on the back of the stock and popriveted it in place. It holds strong and will remain in place when I put in the headliner. I’m just under 6 feet tall and it lines up well over shoulder
Old 10-30-2018, 05:02 PM
HyePo57's Avatar
HyePo57
HyePo57 is offline
do you happen to have a pic?
Old 10-30-2018, 06:20 PM
MARC's Avatar
MARC
MARC is offline
Wouldn’t let me post it, it is in my gallery
nm............
Old 10-30-2018, 06:21 PM
MARC's Avatar
MARC
MARC is offline
Will have to dig up pic of piece before intall
should be on my old phone
Old 11-08-2018, 04:56 PM
mgargiullo's Avatar
mgargiullo
mgargiullo is offline
Please don't secure your seatbelt anchor plate with pop rivets. In a wreck, the weakest joint fails. Ideally, you'd weld the nut to a multidimensional vertical spar that gets welded to both of the horizontal supports above and below.
​​​​​​Your life is worth the extra work.
Old 11-09-2018, 05:42 PM
moonley's Avatar
moonley
moonley is offline
I welded a reinforcement from 18 ga sheet metal and used a threaded tube insert to go through both pieces.
Old 11-09-2018, 05:53 PM
HyePo57's Avatar
HyePo57
HyePo57 is offline
Great fab.... i like that idea.. using the horizontal brace still providing the strength and flush with the side headliner .. great job. I was thinking something similar, using a solid wedge and welded to the horizontal brace and using a longer bolt.
Here is what i have now... following seatbelt solutions instructions... pop riveted and it seems pretty secure since it it behind the “curve”. Welding is always better but when it’s all sinched down, under pressure the curved horizontal brace should provide the same strength whether riveted or welded.
Will improve my installation soon.
Old 12-06-2018, 06:11 PM
bruman's Avatar
bruman
bruman is offline
I put seat/shoulder belts in mine right after I bought it in '77. I drove tow trucks for years back then & saw things that only police & paramedics saw, windshields shattered by skulls, steering wheels mangled by chests, etc. The gory part was the chunks of scalp with hair & blood stuck in the busted windshield. Please don't put lap belts only on the driver's side!! A piece of 2" plate, 3/16" x 2" x the length of the factory brace, curved to fit behind it, will help. I don't really think it's a brace, but you get it. 1/4" would be better!
lasermike
04-23-2022 07:14 PM
Thejudge
1999 to 2016 Super Duty
02-11-2018 09:57 AM
Don Vito
09-01-2015 01:14 PM
sseebart
07-18-2014 05:55 PM
brad1979
17
05-27-2010 02:04 AM
Quick Reply: Adding Seat Belts to the '57
