Starter upgrade
Old Dec 5, 2018 | 09:10 PM
Lockholder's Avatar
Lockholder
Starter upgrade
ive seen a starter upgrade for the 7.3s and it’s bigger then the stock one in size and I can’t seem to locate it.
Old Dec 5, 2018 | 09:25 PM
pirate4x4_camo's Avatar
pirate4x4_camo
The stock Mitsubishi 3.5kw starter is an in-line gear reduction starter, Denso make a 4kw offset gear reduction starter that is about $350 and has become increasingly difficult to find a real one, many crappy Chinese knocksoffs that are anything but an upgrade. Buyer beware.
Old Dec 5, 2018 | 09:28 PM
Lockholder's Avatar
Lockholder
aka stick to the stock one
pirate4x4_camo
I have every reason to believe this is a real Denso
https://cncfab.us/i-30497609-denso-g...8000-8420.html
Old Dec 5, 2018 | 09:32 PM
pirate4x4_camo
pretty much, If that isn’t getting the job done then you got issues
Old Dec 5, 2018 | 09:57 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
The Denso on the CNC Fabrication site is genuine. Here is a video of the starter on my truck.
https://youtu.be/h3LsuCmaD-4
Old Dec 6, 2018 | 07:24 AM
jdw1's Avatar
jdw1
Subscribing
in in the market for a starter for my 2000 X, not really looking for a gear reduction starter tho.
Old Dec 6, 2018 | 08:49 AM
Colorado350's Avatar
Colorado350
When it’s time for a new starter, I’ll pony up for the Denso. IMO, there’s times when an upgrade is worth every penny, in this instance this is one of them.
Old Dec 6, 2018 | 09:15 AM
Sous's Avatar
Sous
FTE Emeritus
Originally Posted by jdw1
Subscribing
Not sure why not other than cost is more. If you buy a quality one though like the Denso, then you get just as much reliability out of it. No modification needed to the truck, it simply bolts into the same place an OEM style starter does. I did use slightly longer bolts though because the mounting surface of the Denso is much thicker.
Your truck, your money and your choice though.
My truck starts in under a second once I turn the key to start with the Denso, AGM batteries and upgraded wiring. The results are clear.
Not sure why the video didn't embed, trying it again.
Old Dec 6, 2018 | 09:30 AM
JT250's Avatar
JT250
I put a gear reduction in 3 months ago or so. I could not wait for the Genuine Denso posted below to ship, nor could I wait for a warranty if there was ever an issue so I went with one of the Chinese versions available at the local stores. So far so good and if I have a problem I can have it swapped that same day. If you can afford some downtime. Go for the original Japanese Denso.
Old Dec 6, 2018 | 09:36 AM
Sous's Avatar
Sous
FTE Emeritus
What Jason has said is also true. Some people have had zero problems or regrets about installing the Chinese gear reduction, others have not been so lucky.
Old Dec 6, 2018 | 09:59 AM
jdw1's Avatar
jdw1
I have no problems ponying up the money, just want to make sure I don’t get a knock off!
So so were are you finding the real thing?
Old Dec 6, 2018 | 10:06 AM
Brother Les's Avatar
Brother Les
A few years back, I overhauled the Starter that I had on my truck. Very happy with the results.
Got the Parts from...
Nation Starter & Alternator,Tractor Auto,Marine,Truck,Small Engine
Old Dec 6, 2018 | 10:58 AM
pirate4x4_camo
Subscribing
all starters for the 7.3 are gear reduction including the stock one.
Old Dec 6, 2018 | 10:59 AM
pirate4x4_camo
I linked to it in post # 3
