2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
P0130 and P0150 codes
Old Dec 3, 2018 | 06:43 PM
GeneLaw1's Avatar
GeneLaw1
Good day everyone,
2011 Expedition Limited here. Last week on the way home from work, the truck started having a rough idle in traffic. The next morning the problem went away and did not come back until this morning on my way in. Its a rough idle coupled with a some slight surging. While the check engine light never came on, my scan tool noted some "pending codes" which are in the subject line. Upon further research, it seems these have to do with the o2 sensors? Just wondering if anyone can point me in the right direction here.
Thanks!
Old Dec 4, 2018 | 09:28 AM
alloro's Avatar
alloro
The 09-10 F-150 trucks had the same issue which turned out to be a software problem that was address with TSB 12-6-16. I know yours is a 2011 but it's close enough to consider it a possibility. I'd check with your local dealer to see if this might apply to your vehicle. The TSB is attached.
File Type: pdf
Old Dec 4, 2018 | 07:07 PM
GeneLaw1's Avatar
GeneLaw1
Thank you! I will definitely look into this.
Cheers,
Allan Paulley Sr.
1997 - 2003 F150
18
Jan 16, 2015 07:27 AM
jhayden
2004 - 2008 F150
Jun 7, 2012 09:19 PM
Jerry79
May 1, 2009 04:03 PM
grumy oldman
1997 - 2003 F150
May 1, 2007 03:09 PM
Todd Varvel
1997 - 2003 F150
Sep 26, 2003 09:25 AM
