2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Bad Battery?
Old Dec 3, 2018 | 05:41 PM
shaneomac78's Avatar
shaneomac78
Bad Battery?
Listen to this. My wife has a 2008 expedition. She drove it to her doctors apointment last thursday morning no problems. Went to leave no start / doesnt crank at all. Tow truck shows up throws a jump pack on it. Still the same not turning over. Battery is 2 years old no problems with starting even when 3 weeks ago it was 15 degrees out. The day it happened it started after sitting all night and was 30 degrees in the morning. Drove it for 30 minutes there. Was inside for 15 min. Then it wont start. Service writter at ford dealer called said it need a battery. What do you think?
Old Dec 3, 2018 | 07:27 PM
Tedster9's Avatar
Tedster9
It's certainly possible, while a 2 year old battery "shouldn't" fail, it happens. It's important that the alternator and charging system is tested, that it is not defective. A bad alternator will soon ruin a good battery, and the reverse can also be true.
Another problem is what are called "phantom loads" or parasitic amp draw. Sometimes a relay will stick, or some engine gee-gaw will continue to draw a small current on a constant basis instead of shutting down like it is supposed to. Aftermarket stereos are also sometimes a problem with this, rear windshield wipers, security systems, etc. An excess current draw won't necessarily kill a battery overnight, but the battery will tend to be under charged and it won't last long. Like say, about 2 years. It's usually expensive to have work performed at a dealer, so make sure they are doing what you're paying them to do. Make sure alternator is charging correctly, and have them make sure there aren't any devices drawing down the battery when everything is shutdown. Some of the electronic modules take as much as a half hour or more to completely shutdown before an amp draw test can be accurately taken.
Old Dec 3, 2018 | 07:55 PM
shaneomac78
thats what i thought as well. I told them to retest the battery and i want to see the print out. It still has a ford esp on it. In my brain though im like if the battery is dead check the charging system. It was running 15 min earlier. Also couldnt figure out why a JUMP PACK wouldnt start it either. Seems like a bad wire to me, power or ground wire to the starter itself. Dealer also stated that it has a failsafe to not start if to low of power. Ive never seen that before. My titan does something like that but it still cranks but if voltage is down ecu doesnt turn on thus no ignition.
Anyone else ever had this issue? Any techs out there want to chime in?
Old Dec 3, 2018 | 08:10 PM
Tedster9's Avatar
Tedster9
Batteries can fail without warning, "running 15 minutes earlier" doesn't mean much as far as that goes. "Batteries die in July, they just don't fall over till December". Hot weather is hard on them. Cold weather reduces capacity.
If they tell you the battery is bad, you'll have to take their word for it, unless you've a way to test it yourself. Tell them you want the old battery back, you'll have to pay the core charge, maybe $10 or something like that. See if they hem and haw more than anything. Then charge it up and have it load tested somewhere else. Many auto parts and farm & fleet type stores will do this for free.
Old Dec 3, 2018 | 08:31 PM
ford390gashog's Avatar
ford390gashog
Sounds like a battery to me. But I would check the charging system. Just curious but what ESP do you have on a 08MY?
Old Dec 4, 2018 | 09:32 AM
alloro's Avatar
alloro
Before blaming the battery you have a neutral safety switch (DTR) sensor and a starter relay on the firewall. Each of which if fails will keep the starter from turning no matter how good the battery is. If the battery was dead I would think the jump pack would have at least caused the Bendix solenoid to click.
Old Dec 4, 2018 | 06:36 PM
shaneomac78
Have had the truck since 2013. purchased a 3 year with it then purchased another 3 year before that one expired. Both are the platinum level (highest level). They will let you buy an esp as long as it has less than 100k on the clock. We have another year or 6k left. Warranty has definitely paid for itself.
Old Dec 4, 2018 | 06:43 PM
shaneomac78
I definitely want them to double check before they start throwing parts at it. I told them to test the battery and send me a copy of the the test. I have a lot of trouble believing its a battery when it cold started 45 earlier. Then was driven 30 min, sat for 15 then wouldn't restart. And it didn't even start with a jump pack hooked up. Everything in my brain points to another issue. Sounds like a lazy diagnosis to me
Old Dec 4, 2018 | 07:44 PM
alwaysfords41's Avatar
alwaysfords41
If it is covered, why are you beating them up over the battery? Worst case is you get a 2 year newer battery, best case is you get a 2 year newer battery and it solves the problem. I drove one of my Expeditions for 3 hours and pulled off for gas. It went from not an issue to dead as a doornail. Drove it another 80k without an issue before I sold it.
Old Dec 4, 2018 | 08:31 PM
shaneomac78
It is not their battery and now the battery is out of warranty. Even if it were it would have to be under the batteries warranty not the cars as it's a wear item. And as you know ford parts are expensive. So a new battery is $200 from them. I definitely want to make sure i need a new one before slapping it in.
also to add all interior functions worked and while trying to start voltage gauge didn't move, it stayed still right in the middle where it should. Radio didn't reset or nothing (which happens in most vehicles when the battery is totally drawn down while trying to start.
Old Dec 5, 2018 | 09:24 AM
Tedster9's Avatar
Tedster9
Your options are pretty limited without testing the battery yourself, and if at a dealer they aren't going to honor the battery warranty. It is very common however for a defective battery to read 12+ volts, have enough voltage to run some accessories, yet choke when asked to provide the high current necessary to start the engine. If they are telling you the battery is defective I would tend to believe them.
I've never warrantied a battery in my life, when they die I go buy a new one. If it failed at under 2 years that might be different I guess. They used to prorate the remaining warranty onto the cost of a new one. So if a "7 year" battery fails after 2 years a new battery should be discounted. But as you mention, not at a dealer.
A multimeter and a full size battery charger will both pay for themselves pretty quickly. And you won't be at the mercy of someone else's opinion on what's going on.
Old Dec 5, 2018 | 05:20 PM
shaneomac78
Talked to the service coordinator today. While checking out the starter the tech moved the cables around and the main power feed fell out of its connector. They are going to fix that and retest the battery.
Old Dec 5, 2018 | 09:12 PM
Tedster9's Avatar
Tedster9
This happened a week ago didn't it?? What are they doin', makin' a career outta this?
Old Dec 5, 2018 | 09:41 PM
shaneomac78
Week ago tomorrow. they are also fixing a leaking exhaust manifold.
Old Dec 6, 2018 | 08:33 AM
alloro's Avatar
alloro
Well that certainly explains why the jump pack didn't help.
bigredcrewcab
2004 - 2008 F150
18
Mar 14, 2019 12:40 PM
jazz77
Oct 28, 2011 10:18 PM
Greywolf
General Automotive Discussion
Aug 22, 2010 07:16 AM
mike L
Oct 21, 2005 09:36 PM
wilmoo
Apr 27, 2002 08:47 PM
