Pistons are the only difference with a Merc crank. The Merc will boost your compression, cubic inches, and low end torque. Breathing is still the limiting factor.
hi folks, whats the difference between a merc. and a ford flathead/
I have a 51 M3.
Thanks
Greg
In a nutshell, the Merc flathead V8 has a longer stroke (4" vs Fords 3.75") giving it more cubic inches (255CID vs Fords 239CID). To compensate for the longer stroke, the wrist pin is higher in the pistons to keep them from hitting the head. To compensate for the larger volume of the cylinder, they have a slightly larger combustion chamber.
Merc crank and pistons with Ford heads give more cubic inches and more compression. Merc heads with a Ford crank and pistons give less compression.
Merc heads, crank, and pistons give you more cubic inches and the normal compression. Basically, it becomes a Merc engine.
I have a 51 M3.
Thanks
Greg
Effietrucker is correct. Also understand that even though you have a Mercury truck, it came from the factory with the standard Ford 239 engine that the Ford trucks did. They were built at the same time, on the same assembly line as the Ford trucks in Ontario and shared all parts with the exception of the trim and name plates.
So the "Merc" Mercury 4" stroke engine only came in the cars?
You got me on that one, Ross. And I should have known better since I was the one that posted that chart. I must be starting to catch up to the age of our trucks...
I was out in Northern Arizona a couple years ago picking up a truck and parts and notice a flathead crankshaft laying on the rear blade behind an 8N Tractor as a counter weight and i thought , nah. Just a rusty old ford crank but i had to look and lo and behold it was a merc crank. I was buying more parts and pieces from the pile in the shed and had him throw it in on the package deal thinking its probably no good anyway, turned too many times. Bent or ??? From bouncing around on the blade.
But nope it was cleaned, checked and turned from standard with rust and now back in a running vehicle. I still laugh about it everytime i think about it.
