Tow Strap
Old Dec 2, 2018 | 09:51 PM
rowyco's Avatar
rowyco
Tow Strap
Anybody got thoughts on a particular tow strap they just can’t live without? Need a new one and have not looked in 10+ years so not sure if there might be anything new I need to look for.
Old Dec 2, 2018 | 09:53 PM
JackalAR's Avatar
JackalAR
Good idea, I need one too.
Old Dec 2, 2018 | 10:02 PM
TX Crawler's Avatar
TX Crawler
Tow strap or recovery strap? If recovery, both ARB or VooDoo both make great products.
Old Dec 2, 2018 | 11:26 PM
mhoefer's Avatar
mhoefer
ARB or Pro Comp or any other brand. 20 ft long, 20,000 lb rating. Keep it dry and clean. Mine gets used every winter, if not for me, to rescue someone else.
Old Dec 2, 2018 | 11:39 PM
Chad149's Avatar
Chad149
VooDoo or Bubba ropes for vehicle recovery. I'll keep a tree saver strap in my kit as well for vehicles that lack proper tow hooks so I can form a "noose" around the frame or axle, along with some shackles.
Old Dec 3, 2018 | 06:29 AM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
I bought this one. 3"/30,000# rating. Price was right:
https://www.ebay.com/itm/20ft-3-3000...item4b4b593a38
Old Dec 3, 2018 | 08:28 AM
Turbo Dog's Avatar
Turbo Dog
I don't have a brand preference but I keep a 30ft long 20K lb rated strap in the truck along with a D ring/shackle to be sure I can connect it to anybody's vehicle. That's all I thought I needed until I tried to pull the wife's car. Having the common plastic molded front and rear bumpers it didn't have anywhere to connect my strap. Turns out it needs a set of J hooks to connect to the unibody underneath the car.
Old Dec 3, 2018 | 09:00 AM
HRTKD's Avatar
HRTKD
ARB may be expensive but you get what you pay for. I have one of the ARB ****** blocks. Love that thing. Very easy to work with and very heavy duty.
Old Dec 3, 2018 | 08:54 PM
JackalAR's Avatar
JackalAR
D-Ring (1 or 2?) or hook on each end?
Old Dec 3, 2018 | 08:57 PM
HRTKD's Avatar
HRTKD
Loops on both ends of the tow strap. D-Rings are used as needed.
Old Dec 3, 2018 | 09:02 PM
TX Crawler's Avatar
TX Crawler
NEVER, ever, use a strap with a metal hook on the end -- it's a great way to get someone killed. D-rings are the way to go but only really work if you (and/or the other vehicle) have a bumper that has tabs on it. A hitch pin will work for the receiver hitch and you can just loop it through the factory rings on the front.
Old Dec 4, 2018 | 12:25 AM
Chad149's Avatar
Chad149
Quoted because this can't be stressed enough!
Old Dec 4, 2018 | 12:01 PM
D3thM3tal's Avatar
D3thM3tal
Yup - being a 4x4 guy I always have recovery gear and multiple sizes for shackles for recovery. Always hook to something sturdy and never use a strap with sewn on hooks, those are full towing things around, not pulling for recovery.
It doesn't matter who you buy them from as long as they are properly rated. I typically run a 2.5-3" strap in the 25-30k range and rarely break them. I've had really nice straps and cheap straps I've gotten from Amazon, the only thing that kills them is abrasion and stupid attachment points.
I always try dead pulling first, tighten strap and try pulling. If that doesn't work you progressively take loner and longer runs at it to get the elastic properties of the strap to pull the vehicle out, or rip **** off.
Whatever you do, stay out of the path the strap or parts will take and be smart about it. For out trucks a 2.5-3" 20 or 30 footer will suffice for most recoveries. I would loop the strap around the front hook and use a shackle to another hook or through a hitch pin on the other vehicle.
bigredtruckmi
All Things Towing
24
Jun 18, 2018 07:54 PM
gearloose1
Dec 29, 2010 03:57 AM
Jeremy2792
Aug 3, 2008 03:50 PM
05harley250
Aug 12, 2006 12:17 AM
bucks-heritage
3.8 & 4.2L V6
31
Aug 23, 2004 01:38 PM
