AC outlets 83V
Old Dec 1, 2018 | 03:27 PM
adamsfbay's Avatar
adamsfbay
AC outlets 83V
I measured the in-cab outlets and found they were both 83V is this normal?
Old Dec 1, 2018 | 03:48 PM
skanj0's Avatar
skanj0
83v with the motor running? That cant be right. Should be between 115v and 120v.
Old Dec 1, 2018 | 04:01 PM
Section179's Avatar
Section179
Are I you using a digital voltmeter set to AC?
Old Dec 1, 2018 | 04:10 PM
DSLTRK60's Avatar
DSLTRK60
The inverter probably uses pwm or pulse width modulation to synthesize a sine wave. In other words it's not a pure wave inverter.
Common multimeters are designed to measure the rms voltage of a clean sine wave only, hence the low reading of 83 volts.
The only way to know is to look at the wave form with an occilloscope.
Old Dec 1, 2018 | 04:14 PM
DSLTRK60's Avatar
DSLTRK60
Here is what pwm looks like. The main thing is the area under the waveform(power) is equivalent to the sine wave.
Old Dec 1, 2018 | 06:27 PM
BillyE's Avatar
BillyE
Use a “true rms” meter and you should get 110-120. It sounds like you’re using an averaging meter.
Old Dec 1, 2018 | 06:51 PM
adamsfbay's Avatar
adamsfbay
Thanks, makes sense (re:averaging)
Old Dec 2, 2018 | 06:55 AM
crewzer's Avatar
crewzer
Exclamation
The OEM inverter output is MSW (modified sine wave or modified square wave; take your pick). It's not a true sine wave (TSW), nor is it PWM.
Here are links to previously posted waveform pictures:
Here are links to previous discussions about the inverter and associated operational problems:HTH,
Jim crewzer
Old Dec 2, 2018 | 11:46 AM
DSLTRK60's Avatar
DSLTRK60
Damn that's a pretty rough waveform.
Andrew Taufen
Mar 20, 2019 10:19 AM
delorenzomp
Dec 16, 2018 04:57 PM
rblank
6.2L V8
May 18, 2017 10:18 AM
stahlzee
Jul 2, 2007 11:50 AM
lestenson
Oct 17, 2004 08:56 PM
