Sponsored by: Auxito
Wiper arm adjustment
Old Nov 30, 2018 | 09:51 AM
Michael Ward's Avatar
Michael Ward
'99 Passenger wiper arm comes to rest off the windshield. I need to adjust it maybe 10 degrees or so. How is this performed? I thought I could just remove the plastic cap and nut and remove the wiper arm and reclock it, but it doesn't seem to come off that way. Is it just stuck?
Old Nov 30, 2018 | 10:34 AM
alloro's Avatar
alloro
Originally Posted by Michael Ward
Is it just stuck?
Yes it is, you might have to use a wiper arm puller, or do a little prying to get it to pop up. Leave the nut on a turn or two so the arm doesn't fly off and scratch your paint when the arm releases.
Old Nov 30, 2018 | 10:37 AM
Michael Ward
I assume its just splined so clocking it is simple once removed?
Old Nov 30, 2018 | 10:51 AM
alloro's Avatar
alloro
I know the rear window one is splined and can be moved to adjust it. I have to admit I don't remember if the fronts have a positioning notch so that the arm can only fit on the wiper shaft in one position or not. As long as the spines are uniform all the way around the wiper shaft you will be able to reinstall the arm in any position.
Old Nov 30, 2018 | 12:56 PM
Michael Ward
And thanks. Don't know why I didn't think of trying a puller. Think I have one for battery terminals that should work nicely for this.
unklscrufy
Feb 22, 2020 05:37 PM
My1964ford
Dec 25, 2016 10:20 PM
limerence
Dec 1, 2013 06:24 AM
Andy_H
Nov 29, 2004 12:32 PM
Jimmy Dean
1997 - 2003 F150
Jan 10, 2004 07:44 PM
