Restoring a steering wheel (polish)
I started off with 80 grit sandpaper and moved down to 320 grit, and things are nice and smooth now, but the hard plastic wheel has a scuffed finish that I want to bring back to it's original lustre.
Any suggestions on how I can get the wheel shiny again? I was thinking about getting some jewlers rouge and polishing it up like a piece of metal, but any suggestions would help.
Thanks
GS
Plastic is much too soft to "sand". It will not shine until you get into the 1500 grit range. I ,myself, would use a Mcguyers clear cut polishing compound with a buffing wheel. Don't spare the staff or you'll spoil the child. You've chosen quite a task and plenty of elbow grease will be required. A buffing wheel will save you hours of work.
You've got hours of work.
Good luck,
KingFisher
