Center console pad fix
Old Nov 27, 2018 | 07:56 PM
Pest007's Avatar
Pest007
So I got tired of looking at my ugly pad pealing up from the corners and decided to go fix it. Toughest part is getting the white plastic piece under the pad to pop up, so I took a picture of the bottom with arrows pointing to the direction you need to push them to release. Most of mine were already broke, but hope this helps. I used Staples that I had to predrill every hole thru the plastic then shove the staple through the rubber pad, then used leverage to pull up staple and guide through the holes.
Arrows indicate direction to push to release tabs
Aligned staple then pulled up and shove in to get tight
Pre drill holes to line up
Old Nov 28, 2018 | 06:04 PM
JJ1101's Avatar
JJ1101
Thanks for posting the pics, I've had the same problem and need to fix it.
DPDISXR4Ti
Jul 23, 2013 12:22 PM
ufvj217
Aug 31, 2012 06:26 AM
offroadracer99
Oct 22, 2010 10:22 PM
TNT in Round Rock
Oct 10, 2010 05:01 PM
