Sponsored by: Real Truck
WRong oil filter?
Old Nov 27, 2018 | 12:44 AM
crazboy's Avatar
crazboy
WRong oil filter?
I changed the oil and oil filter recently on my 2010 6.4l . I used a Shell Rotella oil filter with the dimensions H8.13"xL4.38"xW4.38". I noticed the motor-craft filter dimensions are different(smaller). I also read that with aftermarket oil filters, you are supposed to use a larger oil cap to accommodate the larger filter. well i installed the larger filter with the smaller stock cap, now it wont start. If I go out and buy the motor-craft filter, swap out the rotella for the motor-craft filter, will that solve no starting problem?
Old Nov 27, 2018 | 04:51 AM
seville009's Avatar
seville009
Have nothing to lose by making the correction to the filter. Even if it ends up having nothing to do with the no start issue, you don’t want an oil filter on there that is not at the right specs.
Old Nov 27, 2018 | 05:22 AM
senix's Avatar
senix
go back to the proper m/c filter and cap.
You can potentially starve the motor of oil with the after markets.
BTW the filters are made by racor, so they are very good.
Old Nov 27, 2018 | 10:58 AM
carbonation's Avatar
carbonation
Shell Rotella filters are by Purolator and are 2mm too short.
Motorcraft, Racor, and the cheap PrimeGuard are the correct length.
timbuctooCal
Offroad & 4x4
Aug 20, 2010 07:42 PM
zstyle01
Sep 6, 2007 05:59 PM
rswhitmore
Oil & Lubrication
Aug 4, 2007 02:04 AM
firebug
May 25, 2007 06:17 PM
eco
Oil & Lubrication
Mar 22, 2007 04:08 PM
